HOG won't start
Old Jan 2, 2017 | 08:20 AM
CowboyFrank's Avatar
CowboyFrank
Are the ring gear and primary chain moving?
Only the starter and the ring gear move. the primary chain does not move. Is this maybe something not connected properly on the clutch?
Old Jan 2, 2017 | 08:22 AM
CowboyFrank
j_bee,
That is kinda what I get but the starter engages to gear wheel and it spins but the chain assembly does not
Old Jan 2, 2017 | 08:41 AM
CowboyFrank
only the ring gear. the chain doesn't move. not even a little bounce
Old Jan 2, 2017 | 10:23 AM
j_bee's Avatar
j_bee
Can you confirm from this picture what you are calling the ring gear.
Number 1 or number 2
Old Jan 2, 2017 | 10:31 AM
Campy Roadie's Avatar
Campy Roadie
+1
I'd like to see a video of the starter spinning the ring gear on the clutch basket with the clutch, primary chain and front sprocket stationary.
Old Jan 2, 2017 | 10:56 AM
danhahn's Avatar
danhahn
If yours is a press fit ring gear it may be spinning on the clutch housing.
I believe I've seen some replacement ring gears that are press fit.
Old Jan 2, 2017 | 02:38 PM
Campy Roadie
From 2007 and on the ring gear should press fit. But if I were gonna bet my money, I'd say it isn't spinning on the clutch hub.
Old Jan 2, 2017 | 05:05 PM
CowboyFrank
What I am calling the ring gear is #1 in your picture
Old Jan 2, 2017 | 05:07 PM
CowboyFrank
Originally Posted by Nomadmax
+1
weather permitting (and work of course), I will try and get you a video next week.
Old Jan 2, 2017 | 10:47 PM
WH1_T-type's Avatar
WH1_T-type
Just curious, what is the actual voltage your battery reads at before you hit the starter? Previous experience tells me a battery charged to 12v, while will read good to pretty much anyone, won't start the bike.
