Stator cover removal problem
Old Jan 1, 2017 | 08:31 PM
Jake0261's Avatar
Jake0261
Stage I
Default Stator cover removal problem
Harley wants 800$ to replace my stator. Which is insanity to me. So Ive begun the DIY. I've got everything apart and I'm down to the rotor/stator cover. I pull the cover and get stuck on a lip that seems to only be there to force me to dismantle my entire primary. Any one know a work around? Im not really in the mood to dismantle the entire transmission just to get the stator cover off. The lip seems to have one purpose, and that is to force guys like me to take my ride into the shop. Thoughts? I may take a grinder to it since it's seems to serve zero purpose.
2014 dyna wide glide
Old Jan 1, 2017 | 08:37 PM
bhaxton's Avatar
bhaxton
You won't be the first guy to grind that lip out. Probably won't be the last.
You might stick some rags around the shafts to keep the dirt out
Old Jan 1, 2017 | 09:22 PM
Campy Roadie's Avatar
Campy Roadie
I'd pull the inner primary and grind the lip in case it has to be replaced again. Speaking of which, I would only replace a stator or r/r with Cycle Electric units, never OEM.
Old Jan 2, 2017 | 01:14 PM
Firestormhcg's Avatar
Firestormhcg
I just replaced mine last week. I just ground the inner primary down with a die grinder.
Old Jan 2, 2017 | 01:24 PM
TSheff's Avatar
TSheff
Yea that. Even took the time to give it a nice smooth finish.
Bassin
EVO
17
Jul 25, 2014 05:22 PM
funkydrummer
May 17, 2012 07:34 AM
GGW4Mike
Jun 12, 2009 10:02 PM
gli.der
Dec 7, 2008 03:10 PM
Genghis
Jun 5, 2007 10:29 AM
