Anyone install Baker Compesator Sprocket on there Dyna?
Old Jan 26, 2017 | 08:05 PM
blueangel73's Avatar
blueangel73
Default Anyone install Baker Compesator Sprocket on there Dyna?
Looking for feedback from people that have the sprocket on their ride.
I have that annoying starting issue with the kick back and cough when the engine is hot. From all the reading I have done and after talking to the guy that dyno'd my bike with the install of the power commander, it seems that the most likely culprit is the sub par compesator HD decided not to upgrade when they went from the 88" to the 96" and waited until the 110" models. So I am looking at going with the Baker Compensator Sprocket and the Aditude Adjuster. Has anyone installed the Baker Compensator Sprocket? If so, what do you think of the results? How did the install go (if you did it). What all was required parts wise from Baker in addition to the sprocket kit for the install?
Old Jan 27, 2017 | 09:56 AM
HrdNox's Avatar
HrdNox
https://www.hdforums.com/forum/dyna-...de-time-9.html
This should help out.
Old Jan 27, 2017 | 02:03 PM
arkstreetbob's Avatar
arkstreetbob
I have the BDL unit and really like it. Rode all of last summer with it.
Old Jan 27, 2017 | 03:28 PM
Ghost_13's Avatar
Ghost_13
Yup..., and the chain adjuster
Do it again in a heartbeat
What would you like to know
eta - probably be a good idea to answer the questions already asked - duh
Yes
Love it
Took 8 beers iirc
Need an impact wrench (big un).., or long *** breaker bar (compensator bolt is on tight as **** - and needs to go back on the same )
Need to remember the nut on the clutch is CCW
Need a chain block (chunk of wood also works well)
Need a torque wrench capable of 150 Lbs
Need a new primary gasket and oil
Need a drip pan and several rags (no matter if you drain the primary for days - more oil is going to run out and over the bike / jack.., once the primary cover removed)
Oh.., and need a jack so you're not standing on your head (unless you like to do so)
Need beer
Good music doesn't hurt either
Need a service manual for the torque settings
Need to ensure the chain is in aliment specs after installing the new compensator - mine was with no issues
Yup - compensator wise
Pretty simple install - getting to it is the bitch
Tensioner wise - super easy to put on and adjust
The thing that sold me on the adjuster was the bigger pad compared to the competition
One final note:
There be more **** coming off - than will be going back on (spacers..., washers wise)
Ghost
Old Jan 29, 2017 | 05:45 PM
hell hound's Avatar
hell hound
Dam an 8 beer install
thats quite the project
Old Jan 29, 2017 | 08:04 PM
Ghost_13's Avatar
Ghost_13
I upgraded the clutch at the same time
But yeah - the beer was cold..., and tasting extra good that day - I was in no hurry
It like going for a ride just for fun - I keep speeding up..., only then to start thinking = damn it..., faster I go the sooner its over - so I slow back down
Then repeat it all over
Ghost
Valleyofthegun
Aug 20, 2018 03:02 AM
stal94gt
Feb 25, 2017 10:17 AM
chapy6767
Jan 15, 2017 03:20 PM
HD47knuckle
Shovelhead
May 29, 2014 03:52 AM
ajay450
Apr 8, 2011 11:30 AM
