Wide tire kit
Old Jun 1, 2007 | 08:58 AM
mrcan's Avatar
mrcan
Stage II
Default Wide tire kit
Will someone tell me if I have to use the fender brackets, screws and the cable straps that includes the Dyna Wide tire kit 180?
I have a street bob 06.
Old Jun 1, 2007 | 06:05 PM
darkdyna06's Avatar
darkdyna06
Default RE: Wide tire kit
I got a piece of wire stuck in my stock 160 tirethe other day. I had them put on the SE 180 tire, and it fit with no problem, no kit necessary.The bike seems more stable in tight turns now and looks bitchin,but I've read that some people have had problems withthis tire wearing out quickly. Next time Im going with Metzler 880s.
Old Jun 1, 2007 | 06:38 PM
indigenous's Avatar
indigenous
o6 sb same tire as kit but no kit no problems tire will wear faster than others due to it being soft rubber but so is the stock tire
Old Jun 1, 2007 | 08:59 PM
fj4069's Avatar
fj4069
don't need the kit. you can go as big as 200 rear tire with no kit. just be sure wiring is secure in clips
Old Jun 1, 2007 | 09:16 PM
boogiewithtuck's Avatar
boogiewithtuck
No kit needed - the SE tire is pretty soft and does'nt look to me like it will last me through the summer...
Old Jun 1, 2007 | 11:38 PM
rocklayer2's Avatar
rocklayer2
Can you use a 200 on a steet bob?
ORIGINAL: fj4069
Old Jun 2, 2007 | 02:02 AM
Marlboro's Avatar
Marlboro
I was told that the 180 was the widest I could go on my 06 Wide Glide
Old Jun 2, 2007 | 09:25 AM
NEONNIGHT34609's Avatar
NEONNIGHT34609
can someone post some pics of there tire from the rear thanks
Old Jun 2, 2007 | 10:35 AM
wasp's Avatar
wasp
i have the 180 and lowered, i dont see how a 200 could fit, but ive been wrong before.
Old Jun 2, 2007 | 02:20 PM
steelcowboy's Avatar
steelcowboy
I have talked to alot of people about that 200 and will it fit on the bike? Maybe will it fit on the rim? Not for long you need at least a 5.5" rim to mount it without it puking off the rim under load.
