2016 dyna chain conversion
Old Jun 13, 2017 | 06:02 AM
619DYNA619's Avatar
619DYNA619
I run a 24-55 set up, 13.5" shocks and have the bung king slider. Everything clears and from the looks of the slider there has been minimal contact. That also could have happened when my axel loosened up on me and my wheel was sliding all over the place.
Old Jun 13, 2017 | 12:33 PM
96sled's Avatar
96sled
Originally Posted by Nemosengineer
Can you post a photo of the wear pattern on the rear sprocket ?
i actually just changed the rear sprocket messing around with gearing so that only has like 200 on it .. you think it's getting broken in ? Someone also said it might be a bent output shaft which in that case I would just jump off a cliff ..
Old Jun 13, 2017 | 01:07 PM
hell hound's Avatar
hell hound
I had to replace my output shaft on my 06 after it took some damage from the ipb going bad
pretty big job
MadMario111
Jan 29, 2020 06:58 PM
thanantos
Apr 2, 2018 02:13 PM
SWThomas
Sep 7, 2017 03:34 PM
Chris Sigo
EVO
May 9, 2016 01:40 PM
baxter
Mar 15, 2008 09:31 PM
