Rear Signal Issues
Old Mar 9, 2017 | 05:23 PM
RANGER73's Avatar
RANGER73
Did you happen to also change your lights to LEDs in this parts change out?
Old Mar 9, 2017 | 05:30 PM
megatoph's Avatar
megatoph
Nah, no LEDs, so it's not a load issue I don't think. Both bulbs are standard 1156s I picked up from Pep Boys.
Old Mar 9, 2017 | 06:27 PM
Streetbob_MTL's Avatar
Streetbob_MTL
I ended up having the same problem and after searching countless forum posts I found the problem was the contact where the bulb sits was reversed, there are two pins and when they are mis aligned it throws codes and causes the low range issue. There is quite a bit of slack in the back and can spin pretty easily. Just take a mini screw driver and try turning the round back plate 180 degrees. Fixed it for me!! 👍👍
Old Mar 9, 2017 | 06:38 PM
megatoph's Avatar
megatoph
That's really interesting, I'll definitely give that a try when I get home. How do you keep it from spinning around in there again? Just maintenance now that you know what the issue is?
Old Mar 9, 2017 | 06:44 PM
Streetbob_MTL
There re is a little notch to stop it from spinning but anything can happen I guess when it's rambling along 😉
thyvipera
Jun 28, 2017 07:21 PM
posridin559
Mar 11, 2017 10:34 AM
91hotsoftail
Electrical/Lighting/Alarm
Jun 17, 2014 06:07 AM
sin_cal_fxd
Aug 19, 2012 05:12 PM
jaypee
Aug 26, 2011 08:12 PM
