98 FXDL No Spark Issue
Old Mar 15, 2017 | 11:21 AM
baadharley's Avatar
baadharley
Stage IV
Default 98 FXDL No Spark Issue
Hi,
I'm good at troubleshooting and very tech-savvy. Last started bike about a month ago and ran it for about 10 minutes, as it was only 30deg back then-everything was fine. Last Sun, I coasted bike into the driveway, fired right up, ran for about 2 minutes and flat DIED. Now, just cranks over and does not even attempt to start! Carb is getting and smell gas.
Always on a battery maintainer, but volts were at 12.5, so fully charged it and same result. Swapped out plugs, wires-tested coil and it ohms-out fine. Have 12V at the blk/wht wire...but no matter what, NO sparks using the factory idiot book test. As troubleshooting boredom set in, I hooked up a car 12V coil to the blk/wht wire, rear cylinder, and momentary connected the Neg wire while cranking and it fired!
I'm leaning towards BAD coil?? Though it checks fine? I've ordered an Accel super coil that hasn't yet arrived.
Just wanted to post this out there to see if my thinking is correct-the only parts left are the ign module and the cam sensor/module. I did swap out the ign module with a spare Compufire that I bought years ago, but not sure it is/was good...as had never used it before...and still no spark.
Thx!
Old Mar 15, 2017 | 12:18 PM
Jay Guild's Avatar
Jay Guild
I'd check the neg connections on the bike to make sure all connections are good to the frame. Do you hear the starter relay clicking?
Old Mar 15, 2017 | 12:52 PM
baadharley's Avatar
baadharley
Stage IV
Hi Jay,
Yes, battery and connections all appear good, including kill switch. The starter engages perfectly and engine cranks over just fine-just no spark/combustion. Like I mentioned-everything ran fine for just minutes and just flat-out DIED. Cranks, won't fire and coil has primary power, but no spark...I will add that last time a very similar issue happened last year while riding...I had to coast to the side of the road and would not start.
I swapped out the E-3 plugs(no longer sold!!) that had been running fine for years...with the stock ones and fired right up. I then replaced with NGK Iridiums that have been running fine ever since...also, swapped those out with stock plugs/wires early-on when this recent issue just started on Sun.
Old Mar 15, 2017 | 01:12 PM
NORTY FLATZ's Avatar
NORTY FLATZ
I've witnessed the SE plugs failing. They just do, I guess. Replaced with NGK and fired right up. Put the SE's back in and nothing. Put the NGK's back in and rode for 4 more years. Went home and tossed the other NIB SE plugs in trash.
Old Mar 15, 2017 | 01:42 PM
14GuineaPig's Avatar
14GuineaPig
Try this link. I think you should be able to open the Wiring Diagrams & Electrical Troubleshooting Guide. It has some good info for ignition troubleshooting.
https://serviceinfo.harley-davidson....cle/lookupForm
Old Mar 15, 2017 | 02:43 PM
baadharley's Avatar
baadharley
Stage IV
Thanks All! I may play around with a little more tonight...one thing I didn't try is bypassing the Pos coil wire direct to battery...tho it already has 12V. Also, should receive the new coil by Fri. Funny the parts were cheaper than JP Cycles direct from Accel website and no tax/free shipping. Don't even get me started on paying JP NV sales tax...
Old Mar 18, 2017 | 12:00 AM
dav500's Avatar
dav500
May be a failed ignition or kill switch.
Old Mar 22, 2017 | 09:23 AM
baadharley's Avatar
baadharley
Stage IV
Last week, I bypassed the Pos(+) coil direct to the battery and after cranking a couple of times-it fired, but only once.
Good news is, the new Accel SuperCoil P/N 140407 arrived yesterday and I installed last night-Fired right up!!!
Thanks to ALL! I learned more troubleshooting skills on this than I probably ever needed-just still seems strange the coil just died like it did, but better in the driveway than on the road somewhere.
Happy and SAFE riding to all!
Old Mar 22, 2017 | 10:35 AM
14GuineaPig
Glad it's running, thanks for the update.
MotoOwner
16
Mar 30, 2019 09:58 PM
Terrorshark
Electrical/Lighting/Alarm
Apr 25, 2016 09:52 AM
IronHorse570
May 12, 2011 05:26 PM
flyby
Jun 19, 2010 09:28 PM
zenwarrior
May 19, 2007 11:21 AM
