Changing handlebars on fxdls
Old Mar 18, 2017 | 12:59 PM
hwork's Avatar
hwork
Default Changing handlebars on fxdls
Are all of the connectors on the bottom side located inside the frame? Haven't done one of these before, mainly touring bikes and all of the connectors are right inside the fairing on those.....
Old Mar 18, 2017 | 07:40 PM
Mchad's Avatar
Mchad
Yes, if you look at the bars you'll see the cables going down through the top triple tree and then into the openings on the side of the frame. In there are all the connectors, along with all the cable slack.
Old Mar 18, 2017 | 08:36 PM
hwork's Avatar
hwork
I was able to find them all. They really wad them up in there.....
Thanks for the response though!
Old Mar 18, 2017 | 08:51 PM
Nickd2689's Avatar
Nickd2689
I hate trying to pull them out or repack them. I'm going to be putting 16 inch apes on mine within the next week or so
Old Mar 19, 2017 | 10:42 AM
hwork's Avatar
hwork
I put on 9.5" hardcase risers and lucky Dave's bars. Got them wired just need to do the brake and clutch cables. I'm not looking forward to bleeding that front abs setup.
Old Mar 19, 2017 | 10:51 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Just open the bleeder screw ( with a clear vinyl tube attached) and pour clean new fluid into the M/C. You don't need to work the lever. Unless you already did. If you did, then bleed as usual.
Martin Z Jadan
Jun 25, 2019 05:38 PM
13fxdcHD
General Topics/Tech Tips
May 12, 2019 07:16 PM
nosejimi
Feb 3, 2013 11:30 PM
aces25
Aug 10, 2012 09:53 PM
cadore
Nov 18, 2008 05:04 PM
