Exhaust actuator system trick switch
Old Mar 30, 2017 | 04:28 AM
HrdNox's Avatar
HrdNox
Didn't get that but we did get THESE guys from over there!
Exhaust actuator system trick switch-rammstein_at_wacken_open_air_2013_06.jpg
Old Mar 30, 2017 | 07:27 AM
adm's Avatar
adm
Originally Posted by Tall Timber
I thought ALL OEM exhausts had the flapper valve installed? They do here in AU.
But most replace their pipes so its not an issue.
I think all international bikes (apart from maybe Canada?) get the stupid servo actuated exhaust valves.
There are plenty of options though:
1) Turn it off using your tuner if it allows that
2) Pull the valve open and use a sheet metal screw to keep it there
3) Replace the stupid damn exhaust and discard the servo motor unit (that was my solution)
I am in the UK and have never been pulled for my exhaust noise and it's a pretty loud D&D Bob Cat.
I've also ridden the bike for several thousand miles through France, Belgium, Luxembourg and Germany and again never been pulled. However I am sure the bike is technically illegal in those countries.
So the trick switch is a good solution if you live there, want to keep the stock exhaust, stay (more or less) legal AND have the bike sound better.
But if you want the best sound, the stock HD pipe needs to go!
Old Mar 30, 2017 | 01:43 PM
Smogbob's Avatar
Smogbob
Yep +1 with adm, you can get lucky when you are riding through or on holiday, but problem is when you live here, you get neighbours calling the cops, anonymously obviously and they can come to your house and do a sound check if they want to be ****.....les
Old Mar 30, 2017 | 02:01 PM
128auto's Avatar
128auto
I am sure I don't have one. Worst case I get an exhaust ticket.
Old Mar 30, 2017 | 02:05 PM
Jackie Paper's Avatar
Jackie Paper
A cut out on an exhaust over here is illegal. However, straight pipes with no mufflers is perfectly OK.
Old Jun 24, 2019 | 04:33 AM
papaharhar's Avatar
papaharhar
I want this on vance and hines shortshots.....somebody should make a switch......
Old Mar 17, 2021 | 11:50 AM
Dennis2010Muscle's Avatar
Dennis2010Muscle
Stage II
Originally Posted by Smogbob
I do not know if you guys in the states have this on your rides, here in Europe we all have it, basically it opens and closes the butterfly in the exhaust, closed keeps the noise down, and open gets more noise, well I just found a great little piece of kit for not to many euros, I paid €75 shipped to the door, well it is a trick box, that allows you to keep open the exhaust actuator valve to have the ride sounding like a Harley, and when the cops pull you over for a sound check, you flip the switch, and it closes the valve and your ride becomes a hell of a lot quieter, and you ride away with no fine, I got it in Germany, all is in German but it is just plug and ride.
http://www.blmotorparts.de/auspuffzu...ctive_1091.htm
This is not available any more, do you know other companies who sell this?
Old Mar 17, 2021 | 11:54 AM
Jackie Paper
Wow, sounds like you qualify to have a dual USA citizenship! You ready to sign on?;
Old Mar 17, 2021 | 12:10 PM
TriGeezer's Avatar
TriGeezer
I’ve seen kind of the opposite. A cutout installed in the exhaust. So, when ya hit the switch it opens the exhaust before the mufflers.
SCITOO 2.5 Electric Exhaust Cutout Valve Y Pipe 2 pcs with One Controller Remote Kit,More Horsepower
by Scitoo Auto
Learn more:
Amazon Amazon
Jason3412
Feb 5, 2021 03:42 PM
Jfogle01
Mar 26, 2019 07:42 AM
FlatBlackGlide
Apr 18, 2012 05:43 PM
Mal74
Mar 23, 2011 09:30 PM
HOGNOT
May 15, 2010 02:41 PM
