Dyna models. What's the diff??
Old Apr 3, 2017 | 04:42 PM
Sfguitar44's Avatar
Sfguitar44
Originally Posted by perki48
"So my bike has a 103 twin cam and it's an 883"
With statements like this you may be a troll.
Nope, just ignorant but I'm trying to fix that! 😬😬
Old Apr 3, 2017 | 04:50 PM
perki48's Avatar
perki48
OK, but an 883 is a Sportster, not a Dyna. It is expressed in CC's and the 74,80,96,103,110 etc are in cubic inches.
Old Apr 3, 2017 | 05:11 PM
Sfguitar44's Avatar
Sfguitar44
Yeah, I probably should have said that I have a sportster. I'm just curious about the different dyna models. So between the sportster and dyna families the engines are numbered differently?
Old Apr 3, 2017 | 05:39 PM
REW13's Avatar
REW13
Not all low riders have dual disc brakes...
Old Apr 3, 2017 | 06:29 PM
Tall Timber's Avatar
Tall Timber
With Dynas the numbers are Always a reference to engine capacity 96 cubic inch 103ci 110ci etc etc
All modern sports are either 883cubic centimetre or 1200cc
The names in the sporty models 48, 72 etc are not engine related.
Its all part of the MOCOs master plan to confuse new riders
Mission accomplished.
Spend some time in the pic sections of this forum and also the link cvaria posted and edjamakate yourself some more.
Old Apr 3, 2017 | 06:37 PM
cggorman's Avatar
cggorman
Yes. Sportster engines are designated in metric: Cubic Centimeters, CC's. Big Twins are measured in imperial/SAE: Cubic Inches, CI's. An older Big Twin of 88ci is 1450cc. A 103ci is 1688cc. A 110cu is 1803cc.
Differences between Dyna models vary depending on the years you're considering. Can you narrow it down a bit?
Stock Big Twin transmissions are left side drive (belt/chain on left).
There two different Big Twin Twin Cam designs. One is the "A" designation which all Dynas have. The other is the "B" designation which is counterbalanced for smoother operation and comes in the Softail models. They are not interchangeable.
All stock Dynas have twin shock rear swingarms and front hydraulic/oil damped telescoping tubular forks. Just like Sportsters only beefier...in most cases.
All stock Dynas have three engine mounts: top, front, & rear. Top is a heim jointed link. Front and rear are rubber isolated. Many people upgrade one or all, particularly front and rear, and/or add heim jointed lateral stabilizer links. The rubber isolators can allow some rear tire/swingarm wiggle that adversely affects handling.
Within a given model year:
Fuel tank capacity can vary slightly.
Rake varies.
Instrumentation/ignition switch configuration varies.
Front brake count (1 or 2) varies.
Front tire size varies significantly.
Wheelbase and seat height varies.
Old Apr 3, 2017 | 07:00 PM
Sfguitar44's Avatar
Sfguitar44
Rake varies.
Thank you!!! That cleared so much up!
Old Apr 3, 2017 | 07:01 PM
Sfguitar44's Avatar
Sfguitar44
Another really helpful post! Thank you, it's only day one and this forum is answering so many questions
Old Apr 3, 2017 | 07:09 PM
cggorman's Avatar
cggorman
The biggest differences will be noticed between Fat Bob, Wide Glide, and Street Bob
Line them up side by side and the differences should be obvious. Mostly from the tank forward.
With a little effort (and money), you can generally swap parts back and forth to create a nearly limitless mix.
For example, I'm putting a 2009 Fat Bob front end on a 1999 Wide Glide. More rake, more brake.
Old Apr 3, 2017 | 07:23 PM
multihdrdr's Avatar
multihdrdr
...For example, I'm putting a 2009 Fat Bob front end on a 1999 Wide Glide. More rake, more brake.
Here I fixed it...
For example, I'm putting Fat Bob Tube/Slider Assys with "Wide Glide" Triple Trees on a 1999 Wide Glide. More rake, more brake.
Just doing my part
