Dyna models. What's the diff??
Old Apr 3, 2017 | 07:42 PM
cggorman's Avatar
cggorman
Here I fixed it...
For example, I'm putting Fat Bob Tube/Slider Assys with "Wide Glide" Triple Trees on a 1999 Wide Glide. More rake, more brake.
Just doing my part
Yes, yes...don't forget the custom wheel, fuel tank, main electronics & harness, instrumentation, keyless ignition, lighting, and dampers.
I wanted to keep it simple as an example of the flexibilty of the Dyna platform. Way to go Encyclopedia Brown!
Old Apr 3, 2017 | 07:51 PM
multihdrdr's Avatar
multihdrdr
but, you didn't mention those other things.
Also your statement "More rake, more brake" wouldn't make any sense without mentioning the trees
Old Apr 3, 2017 | 07:53 PM
cggorman's Avatar
cggorman
Yeah, but on a 99 the WG rake is in the neck. I'm just adding a few MORE degrees.
Old Apr 3, 2017 | 08:00 PM
multihdrdr's Avatar
multihdrdr
But if left at...
"For example, I'm putting a 2009 Fat Bob front end on a 1999 Wide Glide. More rake, more brake."
The assumption would have been that you were also using FB trees and then you wouldn't be adding, you would have been reducing Tree Rake (FB are negative rake)
Old Apr 3, 2017 | 08:04 PM
cggorman's Avatar
cggorman
True. You win.
Old Apr 3, 2017 | 08:10 PM
multihdrdr's Avatar
multihdrdr
True. You win.
There no "Win"
Btw, take a good look (very closely) at your 41mm WG trees when you get them off. I think there some rake, but it will in the angled stem not in the angled tube bores like the 49mm trees
Old Apr 3, 2017 | 08:13 PM
cggorman's Avatar
cggorman
There no "Win"
Btw, take a good look at your 41mm WG trees when you get them off. I think there some rake, but it will in the angled stem not in the angled tube bores like the 49mm trees
Interesting. I never put a square to my new trees. I just assumed the rake was in the stem. That's how I modeled them. Now I have to spend hundreds of hours remodeling! (Kidding)
Old Apr 3, 2017 | 08:16 PM
multihdrdr's Avatar
multihdrdr
Yes, your new-to-you 49mm WG trees have the tube holes bored at an angle
Old Apr 3, 2017 | 09:04 PM
Ghost_13's Avatar
Ghost_13
Originally Posted by Sfguitar44
So what's the 103, 110, or 117 for?
To some - a quest for performance
To others - dick bragging rights
Ghost
Old Apr 3, 2017 | 10:48 PM
crtman21's Avatar
crtman21
Not only has this been educational, but extremely entertaining. Thank you! LOL
Bamaglider
Jun 13, 2019 05:42 PM
Magiclint
Jun 17, 2016 09:42 AM
Capri87
Mar 19, 2014 08:00 PM
JakeInMa
Mar 14, 2011 06:23 PM
blackbob
Aug 14, 2006 01:04 PM
