changing the tire/rim
Old Apr 8, 2017 | 07:29 AM
samerkorban's Avatar
samerkorban
Stage I
Default changing the tire/rim
i want to wider the front tire/ rim on my 2013 dyna wide glide but i am worried for the maneuvering
i need to know the best size for the tires that will change the look without affecting maneuvering
Old Apr 8, 2017 | 08:33 AM
Ghost_13's Avatar
Ghost_13
I'm gonna answer your question...., but then again I'm not
You want to change the look - get a square tire..., even paint one orange
So much for my sense of humor
Skinnier the tire - more twitchy it is - fact of life
You speak of handling (maneuvering) - but omit what kind
High speed / low speed / cornering / twisties / off road perhaps
Also omit the tire brand you're running..., and what brand(s) you're considering
A wider tire is more stable - and depending on the handling you seek..., and the tire composition you get - more responsive
Tire pressure is all important - no matter the tire you're running..., or plan to run
As to the best size - with your current rim (which I assume is a 21") - that will change the look
What the hell look..., are you looking for
Many prefer a very wide front tire..., others not so much
Little more insight please - would be most beneficial
Ghost
Old Apr 8, 2017 | 08:15 PM
Dyna100's Avatar
Dyna100
I changed from a 90 to a 120. Had to change rim to a 3" to make it fit. I have a 2003 FXDWG. I made a very positive change to handling. More stable, doesn't Chase road snakes anymore. Seems better in the turns. I think it looks better than the skinny tire. It does seem to get my bike a bit dirtier as the fender does't quite cover the tire at the edges.
Old Apr 8, 2017 | 10:03 PM
cggorman's Avatar
cggorman
Maybe try fitting a modified Fat Bob or Softail fender.
Old Apr 9, 2017 | 10:29 PM
Dyna100's Avatar
Dyna100
Any idea what mods would be required to use one of these fenders ? Just spacers, or something more drastic?
Old Apr 10, 2017 | 08:27 AM
cggorman's Avatar
cggorman
Sorry, no. Would have to start researching how they mount on various models, tree widths, tire diameters, etc. Shouldn't be too hard once you find the right fender. Worst case, you would need to fab new mounting struts/tabs.
Old Apr 10, 2017 | 08:51 AM
cvaria's Avatar
cvaria
Evil skinny tire. Looks good but that thing chases every imperfection it can find. Has to be mastered
you can go wider. If anything, your handling/manuverability will improve.
Old Apr 10, 2017 | 10:12 AM
JAMUS07's Avatar
JAMUS07
Here you go
https://www.hdforums.com/forum/dyna-...ide-glide.html
Old Apr 10, 2017 | 08:36 PM
GREENOHAWK69's Avatar
GREENOHAWK69
I got a new fender from J&P and slammed it to the tire.
Attached Thumbnails changing the tire/rim-20131025_121952.jpg
Old Apr 10, 2017 | 10:33 PM
Dyna100's Avatar
Dyna100
I really like that. Do you remember the model number ?
