2007 Wide Glide Whirring Noise
Old Apr 21, 2017 | 11:43 AM
uglyoldfatguy's Avatar
uglyoldfatguy
Stage IV
Default 2007 Wide Glide Whirring Noise
My 2007 Dyna Wide Glide has just over 30,000 miles, but for some time now (at least a couple thousand miles) it has been making a whirring noise. I finally had a mechanic look at it and he replaced the primary bearing. But the noise is still there, from the time I start it till I shut it off, all speeds and gears it stays the same as far as I can tell. Any ideas what it could be?
Old Apr 21, 2017 | 12:16 PM
Durham man's Avatar
Durham man
My 2012 wg makes a wirley noise from primary from auto chain tensioner, I took it of cleaned it put it back on at a looser tension, and it is better not silent but better, it will probably ratchet back up ! I am gonna go with baker attitude adjuster . But I would think your mechanic would check that , mine u hear at idle in gear or out , clutch in or out , ipb would stop making noise when u clutch in I would think , not sure about clutch bearing ?
Old Apr 21, 2017 | 12:18 PM
Durham man's Avatar
Durham man
Also mine only does it when hot, good luck!
Old Apr 21, 2017 | 12:36 PM
uglyoldfatguy
Stage IV
Thanks. Yeah, mine does it with or without clutch, all gears, all speeds. Someone suggested cam tensioner, but I was told this model doesn't have that??
Old Apr 21, 2017 | 12:50 PM
Durham man's Avatar
Durham man
07 would have cam tensioner unless it was converted to gear drive
Old Apr 21, 2017 | 12:52 PM
uglyoldfatguy
Stage IV
Hasn't been converted. I think I'm going to try a different mechanic. Thanks.
Old Apr 21, 2017 | 03:29 PM
Smogbob's Avatar
Smogbob
Probably a worn inner tensionner, or auto chain adjuster making it just a tad to tight.
RPDLV
11
May 30, 2019 10:23 PM
dCon0ne
Oct 23, 2015 08:13 AM
01ragtop
Jun 22, 2012 10:45 AM
unfknblvbl
Dec 21, 2011 04:27 PM
Road King Kid
May 3, 2007 11:00 PM
