Quick help with paint please
help please !!!!
my fingernails are doing a good job but i have rubbed them all down now. i am afraid to use any solvent as i might mess up my black paint. i am using some bug and tar remover to get the small spots off. to be honest i do not know much about solvents and such . thanks much for any other advice ...been working on the one side for over 4 hours.....
I would try to remove new paint using as mild a solvent as possible. First test it underneath where it won't show.
If it works - it may dull the clear coat a bit underneath it. If so, you can probably buff it out - or worst case, have a new clear coat applied.
Solvents kind of range as follows (mild to harsh)
Alchohol
mineral spirits
xylene
laquer thinner
mek (methyl ethyl keytone)
most 2-part urethanes are resistant to MEK rubs, but it will dull the surface a little.
Just test whatever you do because you can't go back once you've started.
PS - as stated, a clear coat over your paint job would have protected it properly
I do not think i will have this guy do anymore work for me. i was thinking perhaps a clay bar now on the one side that is mostly finished ?
Thanks once again for the advice..sure sounds like you have done some painting ?
thanks much for that info..one side done 99% . i used some fine cut cleaner when i got all the paint off but some specs. no buffer used..just done by hand.
but my business involves applying a special 2-part coating to glass for architectural applications. As such, we deal with coatings quite a bit, and we often do "effects" involving a base coat and clear coat finishes. I am quite familiar with coating chemical tests and the effects of various solvents.
Glad things are working out - I hate when scares like this happen. Best of luck finishing the job up, I'm sure it will come out well.
I may make a run to a very good painter i know tomorrow. see if he can ge tthe other side done for me. he has been doing my cars for many years. his specialty is vetts. so he knows about paint . rained all evening here anyways.no riding that was for sure .
now,if you or anyone else needs computer help...that is what i do .
here's mine:
http://www.battersbyornamental.com/
mud
Good to know about about your trade voyager.
As to the paint removal, if pickin it off with fingernails worx good,
that's what I would continue with.
mud
mud
fingernails about wore off now the only prob .
