FL Style fender - 2006 FXDL
Old Apr 25, 2017 | 08:31 PM
panhead_pete's Avatar
panhead_pete
Default FL Style fender - 2006 FXDL
Thinking about changing up my 2006 FXDL with a FL style rear fender. Is the switchback a bolt on or is it too wide? If so any suggestions for alternatives? Thanks.
Old Apr 26, 2017 | 05:26 AM
turboc's Avatar
turboc
The Switchback rear fender will bolt right up. I have one on my 06 FXDL. I also bought all the stock mounting hardware because I wanted it to be installed as designed. The only thing you will have problems with is the 06 brake light because it won't sit flush to the fender. I solved that by using some closed cell weather stripping around the base of the light housing. The turn signals are from a Street Glide and I scored those on eBay. Just swap the wiring and lenses from your old turn signals into it.
The Switchback front fender is too wide though. Your FXDL has mid glide trees and the Switchback is a wide glide, which is an inch wider. I have an eBay 6" Jesse James Tombstone fender on my 06 FXDL that I'm pretty happy with.
Old Apr 26, 2017 | 05:35 AM
blueangel73's Avatar
blueangel73
Nevermind, mis read the post.
Old Apr 26, 2017 | 06:45 AM
panhead_pete
Thanks TurboC - great info! Much appreciated!
Are the fender struts the same?
Old Apr 26, 2017 | 07:31 AM
turboc's Avatar
turboc
Yes and you can reuse your strut covers. They make a plate to cover the holes left by the old turn signals, but it's not necessary.
https://www.revzilla.com/motorcycle/...dyna-2006-2016
Old Apr 26, 2017 | 07:12 PM
panhead_pete
Thanks again!
J57little
Jul 12, 2019 08:55 PM
Reindeer
Sep 10, 2018 09:31 AM
glidehard
Jun 23, 2014 05:53 PM
Robtarra39
Oct 24, 2012 08:18 PM
kijocoz
EVO
Oct 12, 2011 09:29 PM
