04 vs. 06
Old Jun 5, 2007 | 05:05 AM
rrr2412's Avatar
rrr2412
Default 04 vs. 06
other than the 6 speed and bigger engine what are the other differences between the 04 and 06 low rider? any info will be helpful. thanks
Old Jun 5, 2007 | 02:57 PM
bigmo_dynasb's Avatar
bigmo_dynasb
Default RE: 04 vs. 06
carb vs FI
bigger front forks..
Old Jun 5, 2007 | 03:41 PM
AZ Rider's Avatar
AZ Rider
The engine sizeon an '04 and '06 Lowriderare the same. Other changes are listed below.
Changes to the '06 Dyna
reduced clutch lever effort
new single piece 46mm throttle body
new fuel injectors
redesigned cylinder heads-newintake and exhaust ports
redesigned valve seals
O2 sensors-closed loop fuel injection
no catalysts
active intake system
new engine cases, external oil lines eliminated
more material added to motor mounts
new cam plate
new hydraulic cam chain tensioners-auto mechanical primary chain tensioner
new roller cam chains
new crankshaft splines
increased load carrying capacity cam bearings
new oil pump asemble
6 speed transmission
helical 2nd, 3rd, 4th and 6th gears
new needle bearings for 6th gear mainshaft
new double row output bearing
new transmission case
new clutch shell
starter ring moved to inboard on clutch hub
new engine sprocket/compensator assembly
new rotor assembly
new inner primary housing
new engine to primary gasket
new primary cover
new starter motor
new frame-29 degree neck angle
repositioned motor mounts
integrated fork lock/ignition switch
new seat pan
new swingarm-wider to accomodate OE 160/70 B 17" tire
new axle adjusters
new triple clamps
now uses FLT/V-Rod style steering bearing adjuster
new 49 mm forks
new headlamp and mounting
nw handlebars, clamps and risers
new 10 spoke cast wheels
new 1" front and rear axles
new rear brake caliper support bracket
floating brake rotors
new wrap around rear fender
new battery cover
new battery box w/retention strap
Old Jun 5, 2007 | 03:52 PM
dan69co's Avatar
dan69co
this guy knows his chit!
Old Jun 5, 2007 | 03:54 PM
Sammi's Avatar
Sammi
Thereduced pull clutch is nice.
Sammi
Old Jun 5, 2007 | 07:48 PM
WS6 Formula's Avatar
WS6 Formula
Here's a link for the 2006 upgrades: http://mysite.wanadoo-members.co.uk/...3/06Master.pdf
Old Jun 5, 2007 | 07:58 PM
springerGT's Avatar
springerGT
H-D will let us know.
I ride a 94, and she does great.
It's all about the ride.
[IMG]local://upfiles/5692/41A95B5913C543DC9FDB1D1F14A2B1C3.jpg[/IMG]
Old Jun 7, 2007 | 06:36 AM
rrr2412's Avatar
rrr2412
thanks
Moog Player
EVO
Nov 5, 2009 10:57 PM
Mrs 1of2
"The Florida Crew"
15
Jul 21, 2009 11:21 AM
TexasBowhunter
Apr 11, 2007 12:47 AM
chelsea
Gear and Other Items For Sale
Mar 14, 2007 04:32 PM
Crazyace
Motorcycles For Sale
Nov 14, 2006 11:51 PM
