Ride-on use
Old May 7, 2017 | 01:25 AM
highplainsrider's Avatar
highplainsrider
Default Ride-on use
Can I use ride-on tire sealant on a spoke wheel without a tube in it? Will it seal the spoke openings?
Old May 7, 2017 | 05:27 AM
Davdoodles's Avatar
Davdoodles
I personally wouldn't take the chance. If you want to run tubeless on spoked wheels, there's a company called Outex that makes a kit using heavy-duty rim tape that is supposed to seal the spoke holes. Here's a link. No idea whether they are reliable etc.
Old May 7, 2017 | 05:49 AM
HKMark23's Avatar
HKMark23
no, it will not
Old May 7, 2017 | 02:01 PM
cggorman's Avatar
cggorman
Ride-on will only seal punctures in a narrow portion of the tread area.
Not all spoke rims can be sealed. Even if the spoke and valve holes can be sealed, the bead shoulder must be very smooth so the tire can seal on the metal. For safety, the bead shoulder also needs to have the raised bead retention band on the inboard side of the tire bead to prevent the tire rolling in on itself if air pressures drop.
Old May 7, 2017 | 02:19 PM
multihdrdr's Avatar
multihdrdr
Originally Posted by highplainsrider
...Will it seal the spoke openings?
Try walking to the center
Old May 7, 2017 | 03:27 PM
F86's Avatar
F86
Haha! PERFECT description!
Old May 8, 2017 | 12:04 AM
highplainsrider
Yea that's what I figured. Thanks guys.
texas_tylor
Wheels/Tires
Jul 21, 2015 06:25 PM
latrobedyna
Dec 19, 2013 03:46 AM
magforce
Aug 22, 2009 12:09 PM
bobbyd3
May 5, 2008 08:11 PM
lowleveldriver
Sep 11, 2006 12:53 AM
