1999 FXDL will not start
Old May 8, 2017 | 04:23 PM
kta4isu's Avatar
kta4isu
Default 1999 FXDL will not start
Need a little help here, I have a 99 dyna low rider. Laid it down last fall going about 30mph. Bent a few things, foot peg, shifter, handlebars, minimal damage. While I was working on it I updated several other things, new dash, turn sigs, polished front disc brakes, new headlight etc. Things are all back together, and I cannot get it to start.
Fuel seems good, I’m getting the correct voltage, had battery tested, and its good. All things electrical seem to be working, getting spark, I can see fuel from the carb with the cleaner cover off. The motor turns, but will not fully start. I know there is a BAS on some dyna models, after reading the service manual it states that on a 99 all you need to do is cycle power to reset. I’m not sure what my next step is in my troubleshoot, any help would be great.
Old May 9, 2017 | 02:39 PM
kta4isu's Avatar
kta4isu
Any insight at all would be much appreciated.
Old May 9, 2017 | 02:52 PM
Yamaharley's Avatar
Yamaharley
Did you have it running after the spill before doing the electrical updates? That's where I would start. Also do you have a factory service manual? I would get one so you can see the wiring diagram.
Old May 9, 2017 | 04:14 PM
kta4isu's Avatar
kta4isu
No, It was not running after the spill. I have a service manual yes, and I have combed through the wiring many times, everything appears to be working. I do not think it is an electrical issue. Motor turns over, i have spark, correct voltage from the battery, all lights light up as they should etc. Should I move to the fuel system next?
Old May 9, 2017 | 04:34 PM
Yamaharley's Avatar
Yamaharley
Yes. Drain the tank and fill with fresh gas first. If you can see the carb squirting and it won't start try spraying fresh gas down the carbs opening.
Old May 10, 2017 | 02:38 PM
kta4isu's Avatar
kta4isu
I cleaned the fuel system, did not see any real problems, but got it to fire up. Its been running great since, not sure what my issue was. Thanks for all the help.
Old May 10, 2017 | 06:26 PM
Yamaharley's Avatar
Yamaharley
No problem ride safe.
Old May 10, 2017 | 07:20 PM
skinman13's Avatar
skinman13
I bet you flooded it...it is easy to do with these carbs.
Old May 11, 2017 | 01:11 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Some carbed bikes can be a little cantankerous when it comes to starting after sitting for a while. Usually the front cylinder will fire then the rear will catch up. Glad you got it running.
UncleUtOh
General Topics/Tech Tips
Jun 10, 2018 02:45 AM
Ultraclassic chris
Nov 3, 2016 07:40 AM
orange dragbar
Apr 24, 2015 11:52 PM
CSA
May 13, 2008 07:19 PM
mrbreeze
Jan 6, 2006 08:21 PM
