ordered a tach from HD.........
Old Jun 6, 2007 | 12:55 AM
michelob's Avatar
michelob
Default ordered a tach from HD.........
How hard is this install gonna be?
Any tips. I ordered a 2 5/8 tach that mounts on the bar clamp in the middle.
Thanks for any help!
Old Jun 6, 2007 | 08:37 AM
kpreese's Avatar
kpreese
Default RE: ordered a tach from HD.........
ORIGINAL: michelob
What year and model bike?
Kevin
Old Jun 6, 2007 | 10:46 AM
gman's Avatar
gman
hope you also ordered the mounting clamp and the can that the tach fits into, because the tach doesn't come with these. I installed one on my '06 WG. wasn't too tough, but findinga tach signal was a bit of a challenge. instructions say, and many find it true, that the tach signal can be pulled off the ECM wiring harness, on the left side of the bike. i couldn't get a signal there, and ended up getting it off of the speedo.
Either way, it ain't too tough of a job to do. if you do get into problems, lots of help here on the forum.
Old Jun 6, 2007 | 12:23 PM
KC99JBS's Avatar
KC99JBS
I also want to add a tach to my 07 SB. Can I use one from a 96 Fatboy? My friend has one he'll give me for free if I can use it.
Thanks.
Old Jun 6, 2007 | 12:29 PM
mtnlvr's Avatar
mtnlvr
Easy. Like gman said, the tach comes with the tach, wires, connectors, instructions and maybe a fuse. You'll also need the appropriate mounting bracket and a housing for the back side of the tach.
Wiring was simple on my 98 DWG. The instructions made it look worse than it was as they included the instrucions for multiple models. Just highlight the parts that pertain to your bike and you'll have no problem at all.
All you really need for tool pertaining to tach installation are a wire cutter, wire stripper and a crimping tool.
I guess I haven't actually tried mine yet so I shouldn't say it was easy. Might not even work. I'll find out in a few day when I get my engine back together.
kingke
Apr 2, 2025 12:24 PM
ChasCrewChief
Electrical/Lighting/Alarm
May 14, 2017 07:46 PM
Sanyasi
Jan 12, 2014 12:16 AM
GFredP
Oct 5, 2009 10:48 AM
DOGKILLR
Jun 22, 2008 04:43 PM
