Would you change the fork oil?
Old May 25, 2017 | 07:52 AM
Sandcrab's Avatar
Sandcrab
Default Look at forks
Get down on your knees, and look near the bottom of your forks, on the back side, just above the axle. If there is a #3 phillips screw with a brass/copper washer on the fork, that is the drain plug. Just remove it drain the oil into a container, and sit on the bike and work the forks until you know it's empty.
Then remove the fork tube cap and put some new fluid in, and drain that out also. Then reinstall the screw at the bottom, measure the correct amount for your bike, and pour it into the top of the fork, slowly, while working the fork gently.
Now with that said, I have no idea whether the fork tube cap is under pressure, so take care when removing the cap. My 2009 Ultra was not under pressure, so that's the only experience I have. Maybe look on You tube for a video. It is easy to do and not 4 hours work.
Old May 25, 2017 | 08:47 AM
user 7172984932's Avatar
user 7172984932
You might replace the stock fork springs with a set of Progressives. They aren't expensive but make a big difference
Old May 25, 2017 | 09:03 AM
Ghost_13's Avatar
Ghost_13
Originally Posted by TinCupChalice
You have no real history here; I'd change all fluids. Engine, primary, transmission, front and rear brakes, and the front forks. Your bike is basically 17 years old.
In a heart beat.., without even thinking about it
In addition - change out / replace / torque / tighten / oil / grease
Brake pads..., control cables (oil and adjust)..., carb..., plugs..., tires (potential dry rot)..., belt / chain..., every nut / bolt..., fuel system..., fuel filter..., every bearing / pivot point
iow - nose to *** - go over w/ fine tooth comb
As for the forks..., tear em completely down..., clean thoroughly..., rebuild
Upgrading to progressive is a good move - ONLY - if you correctly set the pre-load - otherwise - you'll be getting less than optimal benefit / preformance
Ghost
Old May 25, 2017 | 10:14 AM
wideglideCVO's Avatar
wideglideCVO
Ghost
Ready to change mine to progressive heavy duty springs. Can you explain to me setting the pre-load so I don't do it wrong, thanks,
Old May 25, 2017 | 10:24 AM
wyotana's Avatar
wyotana
Definitely do it yourself, I did mine yesterday morning, took an hour and a half...and that was because I made lunch and watched some TV while the forks were draining
Old May 25, 2017 | 10:29 AM
fxdli's Avatar
fxdli
While down for the winter, I drained fork oils and installed new springs. Having the fork caps off, I drilled an taped the caps (see pic) next time will not have to remove caps.
Old May 25, 2017 | 01:38 PM
jeffr0000's Avatar
jeffr0000
Pre-load is set by spacer length. The spacer goes on top of the spring. Most seem to use/make spacers made of schedule 40 PVC pipe.
I went through a lot of this in this thread: https://www.hdforums.com/forum/dyna-...-s-repair.html
Page two has a lot of spacer length/preload work with a HD Progressive spring install.
Old May 25, 2017 | 01:45 PM
Yamaharley's Avatar
Yamaharley
+1 on new progressive springs. For under 100$ it's a night and day improvement. Be sure to measure the oil out of each side. Of one is drastically different the seal might be leaking.
My 1996 dyna the oil was black as night and there was maybe 8oz combined. Mine called for 9.8oz in each. Springs were toast. Good luck op.
Old May 25, 2017 | 03:25 PM
Ghost_13's Avatar
Ghost_13
Jeffr added a link to his thread that does a good job of explaining - but if you have add'l questions - post em
Pre load - in a nutshell
There a couple of factors w/ setting the front suspension
Feel:
One end of the spectrum = plush feel (like riding in a caddy)
Other end of the spectrum = harsh feel (think riding a rigid.., or on a log wagon)
Then there's brake dive
Some riders prefer plush (those who don't ride by feel)
Brake dive is maximum
And btw - plush is where I tend to dump bikes - I lose all sense of the bike / road
Those who ride by feel prefer sensitive
Minimal to no brake dive..., and just harsh enough..., to maintain a feel of the road..., and bike
Then there's harsh - feel every bump and hiccup..., pissin blood after a long ride...., no give when braking
Goal is - find the correct length of spacer - to provide the correct pre-load ..., that provides the type of ride you prefer
It works the same for the back springs (although brake dive ain't a factor)
For the rear - it called setting sag
Measure the distance between the frame and swing arm - with the bike in the air (bike / suspension completely unloaded)
Distance = X
Then lower the bike to the ground..., and sit on it (iow load the bike's suspension)
Then measure that distance (same points between the frame and swing arm as for the first measurement)
Distance = Y
Looking for 3/4" to 1" difference between X and Y (the two measurements)
1" = plusher ride
3/4" = stiffer (more sensitive) ride
Less that 3/4" starts getting harsh
Pre-load in a nutshell
We can also discuss oil weight(s) and valving - but that gets a little complicated...., and especially w/ valving - is costly as hell
HTH Sir
Ghost
Old May 25, 2017 | 03:36 PM
Yamaharley's Avatar
Yamaharley
Isn't sag also so the wheel can also extend instead of just compressing? This way the wheel never leaves the pavement and you don't get launched off the seat.
