Help with installing triple trees
Old May 27, 2017 | 02:41 AM
Stevesavage's Avatar
Stevesavage
Default Help with installing triple trees
So I have an '07 street bob that the previous owner put a wide glide front end with some rake in the trees and 27" fork tubes. I recently bought some mid-glide triples that I bought off a member on here and pulled the bike apart and went to install them but seem to be having some trouble. I'll throw up some pics to show what's happening. I have a gap when installing?? Could it be that the wide glide front end had larger bearings?
Old May 27, 2017 | 04:21 AM
union53's Avatar
union53
Is there any wiggle to it? There should be some sort of gap or you're rubbing the tree against the frame and will get some binding. How much I'm not sure. I'll take a look at mine when I get a chance. After checking mine yours looks right.
Old May 27, 2017 | 04:27 AM
skid_pimp's Avatar
skid_pimp
Looks about right to me, from what I can see.
Old May 27, 2017 | 06:09 AM
misfitJason's Avatar
misfitJason
I don't see a dust shield below your star nut
Old May 27, 2017 | 06:16 AM
cggorman's Avatar
cggorman
Looks normal. You have to have access to the preload adjuster nut between the neck and top tree. I think the gap looks dumb, but that's how they're designed.
Old May 27, 2017 | 09:32 AM
Stevesavage
Okay if it looks normal bikes going back together lol
Old May 27, 2017 | 04:27 PM
Nemosengineer's Avatar
Nemosengineer
This...
: Mike
Old May 27, 2017 | 11:43 PM
Stevesavage
So ran into another problem trying to replace the sliders and the damn seat pipe screw is just spinning and won't come out so I can change the sliders and fork seals.
Old May 28, 2017 | 05:09 AM
union53's Avatar
union53
The screw at the bottom of the fork right? When this happens at the shop usually just slide loading the inner tube a little and then popping the screw with an impact gun works. Sometimes you also need to pop it with the impact gun to get it tight again. I'm assuming you already have the springs out right? Whats happening is as you loosen it the damper rod is starting to lose contact with the bottom of the tube so its just spinning with the bolt.
Just remember though it's not a lug nut so don't ride it with the gun just a short burst or two normally does it.
Old May 28, 2017 | 06:47 AM
misfitJason
Put the tube cap back on to load the fork spring and that should give you resistance to use an impact to get the bolt out
