Wide glide dying while riding
Old Jun 1, 2017 | 11:40 AM
wideglide 2014's Avatar
wideglide 2014
1st Gear
Default Wide glide dying while riding
Have a 14 fxdwg 20k miles and no upgrades as far as pipes or motor only cosmetic so far! Riding home from an all day ride and it shut off like key was turned off! Unplugged battery and waited and it started again but did same thing in like 2 miles. Codes are for short in gauge cluster and then some other one also! What does anyone think could be problem. Checked wires so far and all tight. Thanks for any help
Old Jun 1, 2017 | 02:28 PM
Smogbob's Avatar
Smogbob
Have you changed the batteries in your Fob,s and also your main battery could be toast, these are first 2 things to check, in reverse order.
Old Jun 1, 2017 | 02:37 PM
Spy11's Avatar
Spy11
Try checking the ground strap on the battery. Mine broke once so I only had intermittent contact (yes, even broken) for a half hour or so then it completely separated and died. Damnedest thing I ever saw. It was broken under the insulation at the battery terminal connector so I couldn't see the break.
Old Jun 1, 2017 | 03:05 PM
wideglide 2014
1st Gear
Brand new battery and also batteries in fobs! I am gonna try peeling the coating now on the connectors! And warranty ran out 6 months when I I was chasing oil usage down lol.
Old Jun 1, 2017 | 03:11 PM
sailmotion's Avatar
sailmotion
My sons Honda Shadow did the same thing with a toasted stator. Battery was new and fully charged, but clearly was not recharging.
Old Jun 1, 2017 | 03:29 PM
Smogbob's Avatar
Smogbob
Yep as OP said above could be Stator, good video here.
golferguy
Jul 12, 2017 09:58 AM
Repoman0326
Electrical/Lighting/Alarm
May 19, 2017 08:37 PM
JDSporty
Dec 27, 2014 11:50 PM
bukow1
May 5, 2009 09:52 PM
Alan 123
Apr 15, 2008 06:47 PM
