I have a 2003 FLHRI with a parisitic draw of 25.7 amps and will drain a fully charged battery in about 48 hours. When I pulled the security fuse it dropped to .7 amps. The turn signal cancellation module seams to be working correctly (based on performance during ride). I am not sure where to go from here. I would appreciate any advise
First of all 25+ amps is a huge pull, even if you're in the Dyna world with an fl, I have a 2015 Securty system (fob no buttons) and I can go at least a week without running the bike and still start no prob, seems like something is on or draining the electrical system at an alarming rate, again 25 amps is a huge draw, I work on boats where a majority of the systems are 12 volt and I can't draw that many amps with radar, 2 vhf radios, a gps plotter and the nav lights on...it's hard to keep up with a 25 amp draw with a battery charger
That's insane. 25 amps should drain your battery in a couple hours. I don't know off hand what the spec is but I know on automotive applications it's supposed to be less than .035 amps (35 miliamps). I'd imagine that spec would be less on a motorcycle since there's a lot less modules that stay active. .7 amps still sounds high to me but maybe someone else will chime in on that.
That's one Hell of a powerful battery you've got!
Edit: I see your correction now. Much better!
Something is wrong. 25 amps is close to the draw of the starter motor. I would think an alarm system might draw something like 500 microamps or less.
Tell me how you measured that current draw and what type of meter you used.
Okay, I saw your edit.... I think 25 milliamps is a lot for a freakin' alarm system (especially on a motorcycle). But then again.... it IS a Harley Davidson...
