WG Fork Brace
Old Oct 23, 2005 | 12:15 AM
ad2's Avatar
ad2
Default RE: WG Fork Brace
I'm giving up on the brace for awhile. If anyone knows of one that works with chrome sliders I would appreciate the info.
Old Oct 27, 2005 | 04:28 PM
RoadGlideX70's Avatar
RoadGlideX70
I had a similar concern with my '03 Wide Glide (was going to use chrome lowers and wanted a fork brace). Basically, what I was told is the inner diameter was different between the standard lowers and the chrome ones (standard being larger in diameter), so I looked into having the inner diameter of the brace (assembled and torqued) machined to fit the chrome sliders. I didn't do it though (sold the bike instead). That may be an option, if you can find a competent machinist. Just because the Moco or aftermarket doesn't make it, doesn't mean you can't find a way to make it work.
Good luck!
Old Oct 28, 2005 | 09:08 AM
rh8234's Avatar
rh8234
If the HD chrome sliders are made from original equipment sliders as they claim in the catalog, then why would the braces not fit? Is it possible that the seal covers are different on the chrome sliders, and could you use the stock seal covers with the chrome sliders to get the fork braces to fit?
Old Oct 28, 2005 | 07:24 PM
ad2's Avatar
ad2
The chrome sliders covers don't look anything like the originals, so that's the problem. The braces are so finite in measurement that their opening is too small for the chrome covers. HD says they can "mill" the braces, but it chips the chrome, so I'm not good with that. I'll wait for a better answer.
Old Oct 30, 2005 | 01:47 PM
DFowler's Avatar
DFowler
Hope you find something that works.I put the Screaming Eagle ones on my WideGlide.Made a big difference in the handling on rough roads.Donnie
Old Oct 31, 2005 | 04:27 PM
ad2's Avatar
ad2
I'll probably take it to Strokers in Dallas and see is they'll manufacturer one.
Old Oct 31, 2005 | 05:09 PM
rh8234's Avatar
rh8234
The seal covers that come with the chrome lowers do look different than the stock ones, but the stock covers on my '03 FXD are chrome and look fine. Does anyone know if I could use them on the chrome lowers and then would I be able to fit the fork brace?
Old Nov 2, 2005 | 02:09 PM
ad2's Avatar
ad2
Good question. I have my originals in a box in the garage. I'll get them out and see is I can use the original covers on the chrome sliders. The brace attaches to the covers, so if yours works with the chrome sliders than you won't have any problem.
Old Nov 4, 2005 | 10:48 AM
rh8234's Avatar
rh8234
Please let me know if this does work because I'll add the fork brace to my list of stuff to add this winter if it does.
havaglide
Dec 23, 2016 07:08 AM
LunaticFringe
Oct 17, 2014 10:05 PM
Acechaser
Jun 26, 2009 10:58 PM
Booey424
May 11, 2007 08:49 PM
stbobber
Apr 21, 2007 07:25 PM
