Cam suggestions
Old Jun 20, 2017 | 11:49 PM
Nick561400's Avatar
Nick561400
Default Cam suggestions
So I got a 2009 street bob 1584cc I got a big suckered air cleaner and bassani rr2. I usually ride solo and ride pretty aggressive, mostly back roads with some highway trips here and there, usually traveling light.
im looking to upgrade my engine I'm told cams is the next step. Looking for some suggestions, I want to add power to my take off but also add more range to my gears.
I'm a green horn when it comes to this but any suggestions on what the hell to do next would be helpful
Old Jun 21, 2017 | 01:53 AM
103 sedona orange's Avatar
103 sedona orange
http://www.andrewsproducts.com/motor...s/choosing-cam >>
I suggest you start here with educating yourself on how to choose a cam. There are other cam suppliers out there. You're going to get so many guys telling you what they like, so be prepared. By the way what oil are you using. LOL. Good Luck.
Old Jun 21, 2017 | 02:22 AM
fxrnutt's Avatar
fxrnutt
Pretty happy with the 57h in my 103
Old Jun 21, 2017 | 03:34 AM
Albe's Avatar
Albe
http://www.donnypetersen.com/shop/vo...-the-twin-cam/
In my HO, this is a great read, very technical and very informative.
Old Jun 21, 2017 | 01:30 PM
Nickd2689's Avatar
Nickd2689
Definitely read up on all the threads on cams. Everybody's preference is different so it's hard to suggest a specific cam for you. I have the se 259e cams in my 117 lrs. They were part of the 117 kit but I absolutely love it. Another thing to consider would be tuning. I have a power vision and that's the only tuner I'm really educated on, but I think it's one of the best. If you're going to get a new tuner, definitely buy it from fuel moto. They have a lot more/better tunes. I bought my pv from the HD dealer and pv doesn't have a tune for my setup. I ran autotune, but it's still not good enough. Can't go wrong with a dyno tune, but you want a good reputable tuner.
Old Jun 21, 2017 | 01:32 PM
Nick561400's Avatar
Nick561400
definitely going with a dyno tune barnstorm in MA has a good guy to do it they suggested the fueling 543 cams may go with them havent heard anything bad about them
Old Jun 21, 2017 | 02:34 PM
NORTY FLATZ's Avatar
NORTY FLATZ
If you go with a cam with longer duration, you might look at a compression bump.
Old Jun 21, 2017 | 02:50 PM
Nick561400's Avatar
Nick561400
im super new what's a compression bump if u don't mind explaining
Old Jun 21, 2017 | 03:44 PM
arkstreetbob's Avatar
arkstreetbob
For a 96" engine I would use a Andrews TW48H. Lots of power from 2000 rpm to about 4500 rpm. I did a 103 kit and have Andrews TW57H cams.
Old Jun 21, 2017 | 03:46 PM
Nickd2689's Avatar
Nickd2689
good point. And if you do, you might as well do a big bore kit or head work or both while you're there
