Request for guide to change the front & rear brake pads of 2014 Dyna Street Bob. Can't find very good guide from YouTube.
1) Do I need to apply copper grease to the back of the brake pads for front & back?
2) If yes, is there a template that use for Dyna to apply the copper grease? The EBC brake pads I bought does not have template for front & back. There are videos from YouTube that show template to apply at the back of the brake pads for touring model.
3) Understand that copper grease is apply when there will be moving surface between two metals. Isn't grease is slippery when rain flow the grease to the brake pads and rotor?
the rear can be tricky due to the pad guides and the pad backings. Highlighted
i do put a little caliper grease on the back of the pads but, it is not required and may not even be good practice.
covered in the service manual. we can help you through it but, next time... get yourself an OFFICIAL service manual it covers all the torques specs and such.
+1 on above, and make sure when you put the calipers back on that the pads have not slipped out, also before you start put something in between the front brake lever and the throttle, I normally use a rubber ball so you do not squeeze that brake, otherwise everything will pop out of the caliper, I also zip tie the rear brake to the frame in case I hit it by accident moving around if you are in a tight space, or anybody else touching it.
Thank you very much for the information. I saw the first video before, it is very good guide with english subtitle.
The image for the front brake, not sure is it ok to apply a little of copper grease to the w/m shaped clips, to have some protection against rust and metal to metal rub.
The second video at timing 4:25, not sure why the person want to remove the Phenolic insulator. Not sure is it ok to apply some copper grease after that so that next time remove is mush easier.
Here are some videos show that copper grease is apply on the back of the brake pads. Those are touring model.
timing start @ 12:00
Mine Dyna is the 2014 model. I have the 2013 Dyna service manual. I had read the service manual, no copper grease and no template require written in the service manual. But after seeing many YouTube videos showing copper grease apply to touring model, tend to get confuse is it necessary to apply copper grease. Understand that if the service manual never mention, then follow the manual is correct, isn't it?
those vids you posted are touring brembro calipers, not the calipers that are stock on your bike. very different set up, i'm running those on my sportster. the hd touring pads come with those templaes ans grease, my lyndall z+ pads did not come with the copper grease.
i used/use caliper grease on my stock calipers with lyndall pads.
Can anyone tell me what size wrench is needed to remove the retaining pin on rear brake pads on 2008 Dyna Super. Very small and I can't seem to fit anything to it.
Retaining pin.
1/4" 12 point will get the job done. It has to be a 12 point, or you're buying a new retaining pin...
Tin, i've seen the post before referencing the 1/4" 12 point. But, I'm pretty sure its metric. Do you know what the metric size is?
It is metric, I think it's a 6.25/6.30mm, but the 1/4" 12 point will work. I've got some nice tools and I've never found a proper metric fit for that retaining pin, the 1/4" 12 point is the closest I've gotten to a solid fit on that retaining pin...
