Front fender
Old Jul 9, 2017 | 07:41 PM
mjeddy78's Avatar
mjeddy78
6th Gear
Default Front fender
Hi. I just got my dyna wide glide a few weeks back. It is missing the front fender. I bought one off eBay and the holes line up but not wide enough to sit flush against the forks. My question is could I use some kind of spacers and what size in diameter are the 4 bolts? Should I use lock washers?
Any advice is appreciated. Thank you
Old Jul 9, 2017 | 07:58 PM
TinCupChalice's Avatar
TinCupChalice
No year of the bike given given; how typical is that. Let's play a guessing game here. 49mm forks? A '10 or later?
If it doesn't fit you bought the wrong front fender for a Wide Glide.
Play with all the spacers if you want to try and make it work, or buy the proper fender and be happy
Old Jul 9, 2017 | 08:56 PM
cggorman's Avatar
cggorman
I think vulcanworks makes adapters/spacers.
Old Jul 9, 2017 | 09:18 PM
JohnMn's Avatar
JohnMn
I swapped the front fender out on my 09 FXD and needed different spacers, my local Ace hardware store had them in a drawer (Chrome, various sizes) with all the other nut's an bolts an such,, bring the fender in the store with you and get the bolt that fits (chrome).
Old Jul 9, 2017 | 09:20 PM
DynaKid94's Avatar
DynaKid94
if it's an 05/earlier wide glide, i'm guessing you got a narrow glide front fender, plenty of companies make adapters. anything late model, i'm not sure...
Old Jul 10, 2017 | 09:45 AM
multihdrdr's Avatar
multihdrdr
Yes...You can probably figure that out...Yes, if you aren't using lock nuts
Good luck
bonesmutley
Shovelhead
Jul 24, 2015 04:22 PM
slyedog
Oct 2, 2014 02:49 PM
hellbob37
May 19, 2012 08:10 PM
user 87208922
Mar 12, 2010 02:43 AM
uneasy_rider
Feb 13, 2010 09:44 PM
