Hey everyone
Old Jul 13, 2017 | 12:54 AM
Dynafb's Avatar
Dynafb
Stage II
Default Hey everyone
Hey everyone how's it goin? I have some questions about my 2011 Dyna fat bob. When I turn the ignition on and turn the off button to run, the bike starts without me touching the start button. And it will continue to turn over and spin the starter after it's running, but if I turn the run switch back to off it stops. Has anyone had this issue before and if so what was the issue and how did you fix it? I think it's a bad starting switch but I wanna be 100% sure. Any and all advice would be much appreciated
Thanks
Old Jul 13, 2017 | 06:11 AM
cggorman's Avatar
cggorman
I agree with your diagnosis. Could also be the starter relay.
Old Jul 13, 2017 | 07:03 AM
Dynafb's Avatar
Dynafb
Stage II
thanks for the advice and help, I plan on checking the starter relay and all the wiring while I have it apart. Now I'm trying to figure if I've got to replace both switches or if I can replace just the one. And if the new one comes with the wiring harness attached or if I haft to wire it myself. Because I've been told both ways and seen both options lol
thanks again
Old Jul 13, 2017 | 06:45 PM
Mchad's Avatar
Mchad
You could get a can of contact cleaner and (with the switch off the bars, or at least take out the screws and cover the area so you don't splatter your paint with the spray) and spray the hell out of the mechanism while pressing it in and out. Also, does the button spring back out when pressed? Bad spring maybe?
hellbilly78
Aug 18, 2014 02:59 AM
paul0311
Dec 7, 2013 02:30 PM
Freewheelin Franklin
General Topics/Tech Tips
Aug 19, 2012 04:11 PM
86flst
Jun 18, 2007 05:39 PM
TBone2
Shovelhead
Aug 22, 2006 08:25 AM
