MIrror vibration fixed and front wobble gone
Old Jul 17, 2017 | 02:45 AM
Smogbob's Avatar
Smogbob
Default MIrror vibration fixed and front wobble gone
I know there are a million threads on this, but I had mirror vibration, left was worse than right, and the front wheel would wobble when I was slowing down and holding the bars ever so lightly, well I weigh 250 lbs and had my Fatbob shocks set at number 4, well I simply changed the shock setting to number 3 and guess what vibrations in mirrors gone, and wobble also, I could not believe what was happening, so I set my shocks down to number 2, and guess what wobble and vibration was back, so at 2 and 4 I had wobble and vibration, and at 3 no wobble and mirrors flat as a lake, I have no explanation for this, as it is surely a geometry thing, and I was rubbish in school.
Old Jul 17, 2017 | 05:44 AM
blueangel73's Avatar
blueangel73
Interesting, very interesting!
Old Jul 17, 2017 | 08:15 AM
archergodwin's Avatar
archergodwin
Harmonic frequencies... different masses resonate at different frequencies.. larger masses at lower frequencies, small masses at higher. You apparently affected the harmonic of all those parts bolted together with the shock setting... kinda weird, but then... science
Old Jul 17, 2017 | 01:09 PM
Smogbob's Avatar
Smogbob
Yep I have to agree with that, and talking about Harmonic vibration, I was thinking that my baffles in my Sebring mufflers held in by a springclip where making a weird noise, it turned out to be the heat shield edge was slightly touching the header pipe, so I bent it out just a little and noise gone, I bet this gave a little vibration also, possibly the one everyone is trying to track down in the fingers.
Another addon to this is you have changed your exhaust or mufflers, have a good look under and see if any of the brackets are close to the brake rod etc, mine was just touching the brakerod, so another gremlin out of the way.
Old Jul 17, 2017 | 06:58 PM
robertomendo's Avatar
robertomendo
A little over a year ago I did the clevis pin mod on my 2012 Switchback and the vibrations have been mostly gone but I recently put on pro-action shocks and to my surprise the residual floorboard and mirror vibes are even much more gone.
HemiOrange
Jan 29, 2014 08:44 PM
smtrickett
Nov 4, 2012 05:07 AM
TexasBikeBoy
Jan 23, 2010 05:37 AM
Tucker99
Feb 29, 2008 10:52 PM
dragonfiregirl
Apr 6, 2007 10:02 PM
