Vibration
Old Feb 28, 2008 | 02:42 PM
Tucker99's Avatar
Tucker99
Default Vibration
Gents,
I read somewhere that putting a roll of nickels in each side of the handlebars reduces vibration significantly. Is this an old wives tale or what? I can use all the help I can get.
Old Feb 28, 2008 | 02:45 PM
rh8234's Avatar
rh8234
Default RE: Vibration
It may reduce the evidence of the vibration when you look in the mirrors, but it won't do anything to actually reduce the "cause" of any vibration.
Old Feb 28, 2008 | 02:47 PM
SteveB FLH's Avatar
SteveB FLH
Don't know 'bout that one.......But you would always be ready to pay at the the toll booth!
Old Feb 28, 2008 | 03:00 PM
screwball's Avatar
screwball
Harleys vibrate, always have, probably always will. One of the characteristics we know and love
Old Feb 28, 2008 | 03:10 PM
Fun Rider 05's Avatar
Fun Rider 05
Today they sell handle bar weights.
Old Feb 28, 2008 | 03:13 PM
carpetride's Avatar
carpetride
well I looked at some of your posts and it looks like you have a heritage...unless it's a pre balanced motor bike, vibration shouldn't be much of an issue unless somethings wrong. Your gonna get a little at speed since your motor is hard mounted but my 05 softail standard was very smooth for a Harley and my road king is alsowhen youget aboveidle
Old Feb 28, 2008 | 03:20 PM
golfblues's Avatar
golfblues
Hey, at least you'll never run out of cash when your with the bike. Might be a hassle gettig it though!
Da Gumpmeister's Avatar
Da Gumpmeister
Laffing at myself. When I'm riding the pan at nite, look in the mirror. There's lights back there. NOW, I can't tell if it is an 18 wheeler or another sickle, "ALL" I know is there is "something" coming up behind me.
As stated, all the nickels do is reduce the "effects" of the vibration. Same as rubber mounting the motor (have always HATED that term, motors run on electricity, ENGINES run by internal combustion.), Flanders risers, BIG foam grips, any number of ideas over the decades. You can spend a good chunk of change balancing the engine out. Helps a lot, but vibration is going to be an inherent part of the design of an HD V twin. By trial and error, have been able to reduce it tremendously, by finding the "sweet" spot in the RPM, then go to work gearing the primary, trannyand final drive to the speed I want at said RPM. But again, you'll never "eliminate" it.
Old Feb 28, 2008 | 03:24 PM
Old Bones's Avatar
Old Bones
If you send me the two rolls of nickels your handle bars will stop vibrating.
Old Feb 28, 2008 | 03:27 PM
DeJavu's Avatar
DeJavu
Adding weight to the handlebars at or near the grips changes the "resonant frequency" of the bars. You may minimize vibs at certain rpm, but it may amplify vibs at idle for instance. If you experiment with various weights you might find the best compromise. Play with it, you may improve things at cruise speed for instance. Good Luck.
I used to be a "shake and vib" research tech and have done a lot of this sort of thing.
