HELP!!!!!!
Old Jun 10, 2007 | 07:34 PM
hawg68's Avatar
hawg68
Default HELP!!!!!!
Ok I put a new set of handlebars on my bike. Did not need new cables and had not problems switching but now when I turn the key on my front turn signals flash about six times and then my turn signals dont work and my speedometer and odometer dont work. The odometer will come on if I push the button on the back side though. Can anyone tell me WHAT THE HECK IS GOING ON?
Old Jun 10, 2007 | 07:47 PM
glideridemike's Avatar
glideridemike
Default RE: HELP!!!!!!
Internal wiring? Cut and solder anything? Did you have to unplug anything? If so make sure you have all the correct color wires plugged together, in other words make sure the plug wnet back together correctly. You're going to have to double check all your connections. If you had to pull any on the harness something in the backbone may have come loose.
Old Jun 10, 2007 | 09:44 PM
hawg68's Avatar
hawg68
I hadto pull a little bit but didnt have to unplug anything.
Old Jun 11, 2007 | 02:20 AM
hawg68's Avatar
hawg68
It's fixed! Thanks for the response. I pinched a wire and blew a fuse.
Old Jun 18, 2007 | 01:23 PM
glideridemike
great news,
ride on
rustybit
Jun 12, 2016 01:11 PM
bmw_stu
Oct 20, 2013 08:08 AM
Northbound Southerner
Oct 8, 2013 11:28 AM
OldTyme
Aug 12, 2012 01:30 PM
s13_marine
Oct 9, 2011 02:56 AM
