Powervision tubes FXDLS
Old Aug 15, 2017 | 04:43 AM
VoiceofReason44's Avatar
VoiceofReason44
Default Powervision tubes FXDLS
I have a 2017 FXDLS. Using a powervision with dynojet loaded tunes. Have the SE forward air filter and a thunderheader. The only tune that applied to my bike was high flow air filter and Basani 2 into 1 exhaust. Checked for updates, that was it. Am I good with this?
VoiceofReason44
I meant to have it titled "tunes" not "tubes".
Old Aug 15, 2017 | 05:22 AM
Mchad's Avatar
Mchad
It's close enough to get you started. Do 4-6 autotune sessions and you should be good.
Old Aug 16, 2017 | 03:43 AM
VoiceofReason44
Just so I understand, set up the PV to run the auto tune and go for a ride, log the data and import the data, correct?
Old Aug 16, 2017 | 05:45 AM
End Loser's Avatar
End Loser
I think what he meant was, flash the tune you found first, then do the 4-6 autotune sessions. The first flash will get you close and the autotune will dial it in closer.
Old Aug 16, 2017 | 06:14 AM
Mchad's Avatar
Mchad
Yes. Load your preferred tune. Run the auto tune procedure per the manual (sorry, don't recall the step by step at the moment) save the new tune to a new slot. Flash the new tune. Repeat auto tune 3 or 4 more times, each time starting with the newest tune.
There's a huge sticky in the ecm tech section on the power vision, a lot of good info in there - suggest you take a look.
https://www.hdforums.com/forum/ignit...-by-admin.html
Korbenw7p3c
Feb 23, 2020 10:56 PM
NCBANDIT
General Topics/Tech Tips
Jan 8, 2017 12:09 PM
splicer
Jul 30, 2013 06:03 AM
txphatboy
Jun 12, 2012 06:13 PM
JCK
Sep 14, 2010 07:44 AM
