Seat Bolt Gone!
Old Aug 20, 2017 | 08:30 PM
Krash26's Avatar
Krash26
Well, picked up the new bolt, retaining washer, which is a stupid piece of plastic, and went with the knurled thumb screw. I've got some small gauge electrical wire and if you tie the end with knot, drop the bolt thru it, then run the wire thru the hole from under the fender, just pull it straight up. No removing the fender...easy.
So no epoxy? How about a bit under the retaining washer to the fender? Or just leave it alone...
Old Aug 20, 2017 | 08:39 PM
Ron750's Avatar
Ron750
I didn't like using the Phillips head screw so I paid $20 for a HD thumbscrew. I had a lazy Indy that didn't tighten it, and it fell out.
Sk I bought a bag of Stainless Steel bolts, and lock washers. 1/4" 20 x 1/2". Problem solved.
Old Aug 20, 2017 | 08:44 PM
DonN's Avatar
DonN
I had the thumbscrew and then someone actually stole it and replaced it with a cheap allen headed one. At least didnt take my seat.
Old Aug 20, 2017 | 09:23 PM
Suede Blue Man's Avatar
Suede Blue Man
That's why I use an allen, don't want some *** to run off with my seat.
I said some *** to run off with my seat
Old Aug 21, 2017 | 11:18 AM
Krash26's Avatar
Krash26
Geez...I just bought the thumbscrew. Guess I'll buy an allen and keep it, just in case. Pretty sure no one would want my seat as its a reduced reach type. Unless they're a short little sh**t!!!
Old Aug 21, 2017 | 12:15 PM
nevil's Avatar
nevil
No need for epoxy- just use blue locktite
Old Aug 21, 2017 | 12:42 PM
izhd's Avatar
izhd
it happens. try this https://www.imzzelite.com/shop/motor...seat-bolt-kit/
Old Aug 21, 2017 | 01:14 PM
Bville-Bud's Avatar
Bville-Bud
I have had a thumbscrew on my seat for years. Many older metrics didn't even have a locking type retainer. I don't worry about someone stealing my seat (and I worry about everything).
Old Aug 21, 2017 | 04:49 PM
bigbadpoppa's Avatar
bigbadpoppa
Originally Posted by freebaggin
This is what I was going to suggest, super easy.
Whenever washing my bike or doing safety checks before riding, I just make sure it's tight. I would not put locktite or anything like that. And be sure not to over tighten.
and a rubber washer to hold it in place.
Old Aug 21, 2017 | 05:28 PM
Pokey151's Avatar
Pokey151
Originally Posted by Bville-Bud
Bummer, sounds like a good time for a thumb screw bolt instead of the phillips that come stock. I throw those things away first thing.
X2
I did this but bought a spare, I keep it in my battery box bag.
