Seat Bolt Gone!
Old Aug 21, 2017 | 11:01 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
Originally Posted by nevil
No need for epoxy- just use blue locktite
Told him to use Locktite a few posts ago but I guess he's a little bit dense!
Old Aug 22, 2017 | 06:19 AM
JayStronghawk's Avatar
JayStronghawk
Cool
Originally Posted by Dog812
They are dirt cheap I wouldn't bother, just check your seat screw with your fingers every couple weeks.
You don't need a Jack to re install. Put a long zip tie through the nut, pass the zip tie up around the tire and find the hole. Pull it through, put on the clip.
Exactly what I did with a length of 14 gauge Cable with a Knot got in my Drawer with other special tools for certain jobs that rarely occur , just in case need it again for mine or another's Ride.. Dyna is not the only Bike that has this problem .. Also happened on my 04 Heritage which was a bit harder to do but all of them have the same principal for reinstall ..
Old Aug 22, 2017 | 08:27 AM
Krash26's Avatar
Krash26
I also took a piece of 18 gauge wire and pulled the bolt up with that from underneath the fender without removing it. Worked like a charm and took about 5 mins. The way that bolt seats is bad though, once that plastic retaining clip is on, its still so loose. I'm already thinking if I don't keep checking the thumb tight screw, I'm going to lose it again. I think i'm going to put some blue Loctite on the thumb screw, just to be safe.
kstew74
Jun 27, 2024 04:23 PM
Booey424
Jan 7, 2014 09:25 PM
nyokie
EVO
Mar 28, 2012 05:56 AM
Droop
Mar 30, 2011 05:17 PM
bobby5
Apr 22, 2008 06:41 PM
