Handlebars extension kit on stock bars?
Old Aug 20, 2017 | 08:43 PM
Str33tBob's Avatar
Str33tBob
Default Handlebars extension kit on stock bars?
I have an 06 street Bob and want my bars a inch or so higher. My wires are external but I do have that center cover over the risers. I see that I can extend it but when I search I don't come up with much results on these bars. Anyone done it or know some good options? I'm looking for chrome for sure and would like a kit so I get bolts as well.
Old Aug 21, 2017 | 12:07 AM
loopie's Avatar
loopie
try handle bar risers spacers,, DK forum vender has them
Old Aug 21, 2017 | 12:26 PM
TUCCI's Avatar
TUCCI
You should be able to raise the bars up 1 inch without running out of clutch and throttle cable length. The Wild1s are 10 inchers but higher than the stock because of the pull back and if they were any higher the clutch and throttle would get tight in the turns. That probably equates to 2 inche height with the pull back the Wild1s give.
Old Aug 21, 2017 | 06:31 PM
Str33tBob's Avatar
Str33tBob
My issue is do does not make a chrome riser, and I have found some but I would need longer bolts. Can I just grab some from home Depot that match the threads? Nobody has experience with this? I'm amazed nobody has tried this. I attached a photo I found online of the type of risers I have. Granted mine just say Harley Davidson but you get the point.
Attached Thumbnails Handlebars extension kit on stock bars?-16-hd-street-bob-factory-customization-4-large.jpg
Old Aug 21, 2017 | 07:20 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Check out Rox Handlebar accessories.
https://roxspeedfx.com/collections/harley-vtwin
Old Aug 21, 2017 | 08:04 PM
Str33tBob's Avatar
Str33tBob
I'd like to rise from the bottom and only an inch or so. Although those risers are nice, just not for me
Old Aug 21, 2017 | 09:02 PM
REW13's Avatar
REW13
So you don't want a riser?
What size bars do you have now?
Saw some wedge looking things on Amazon as I look for solid black risers three to four inch.
Old Aug 21, 2017 | 09:21 PM
Str33tBob's Avatar
Str33tBob
From what I read it's known as riser extensions. I want chrome and the bars are 1". The risers I have now are a bit less than 1" I think. I'm going to measure tomorrow. I want chrome.
Old Aug 22, 2017 | 10:37 AM
JohnMn's Avatar
JohnMn
You've got things a little confused here,, it's OK.
You need/want new "risers".
The center cover is the "clamp",, you keep that with the same bolts and use it.
Risers of different heights (in chrome) are available from about 100 different suppliers for Harley Davidson bikes.
The risers are simply removed/replaced with a bolt through the bushings in the upper fork brace, it's takes a 3/4" wrench.
Just search for risers;
http://asset.lemansnet.com/static/si...v2/#?page=1190
Gar1414
Apr 22, 2021 08:57 AM
xantasm
Aug 23, 2014 09:31 AM
ghoticov
Mar 8, 2013 04:45 AM
Papa Bear
Jun 27, 2009 04:17 PM
johnpiech
Apr 6, 2006 11:01 AM
