well I finally ordered my 2 inch tank lift from the link above. I was gonna just fabricate one from flat stock I have laying around and have it powdercoated but I stumbled on this one and I really like how solid it looks. I figured **** it, for 50 bucks I might as well. That way I don't have to wait for my pc guy to get a big enough order. Once I get this installed I'll figure out where I'm gonna put my oil catch can, fabricate a bracket for it, then have my bike dyno tuned (assuming I don't do a larger big bore or cams....kinda considering bumping up the 117 to something bigger or picking a different cam, or both...we'll see)
anyway ive tried searching the threads but can't seem to find a definitive answer so if anyone has noticed a difference in the miles they can go per tank please let me know what to expect. I know the fuel have will be even more inaccurate but I could give a **** about it cause it's about useless except for goin "oooohhh pretty lights hur hur hur". I just use the tripometer.
You will lose about a half gallon from a 2" lift. For my bike I just go 150 miles on the odo and fill up, Usually takes about 1.5 gallons to fill up at that point.
I'd like to see pics of before and after please. And a pic of the kit. Curious about doing this?
I'll take pictures as soon as the kit comes in. Should be here by the 26th. It really is simple all I'm doin is removing the bolt at the front of the tank, and installing a spacer to lift it.
Make sure you have enough slack in the fuel crossover tube. Sometimes they need to be cut and replaced with slightly longer.. If so, easiest way: Get your longer tube cut to the right length. Put two clamps (vice grips work) on either side of the existing tube nearest the tank fittings - being careful not to crimp the fitting! Once clamped down to cut off flow, cut the hose in the middle (rag in hand to catch drip).
Cut off existing pex clamp. Put a third clamp in the middle of new hose. Pull off one side of old hose. Quickly slip new hose on, making sure new pex clamp is on if using (otherwise standard hose clamp can be put on afterwards.) Clamp in the middle will keep fuel from flowing, and a couple of rags will catch the drip. Just move quick. A second set of hands holding the rags helps keep it clean. Repeat other side. Test fit before crimping pex clamps (again, if using).
Done.
yea I believe I should have enough with the 2 inch lift but we'll see. If not I'm just gonna get fuel line and clamps from Murrays. I hate the crimp style clamps that you only use once. But yea thank you for the advice. Maybe this time I'll actually do it without dumping fuel all over the motor.
What is the purpose for the tank lift is it for better cooling and air flow to the engine. Was looking at them DK products sells them along with fork vents was looking at them.
its ts for both looks and better air flow to the motor. Plus it makes cleaning the top of he motor easier and more accessible. I like the looks of it, better lines and the cooling/cleaning is a bonus.
Originally Posted by Nickd2689
Ok good to know. Thank you. I really didn't think it'd be enough to notice but wanted to see what others had to say about it
You don't "loose" anything. You're reserve indicator will probably come on sooner, indicating you have less gas in your tank than you actually do. This just takes some rapid getting used to.
When the "R" light comes on, run your bike till your reserve reads only "LOW FUEL". Then fill up, noting the amount of fuel you have taken on. The difference between this and your tank's stated capacity is what you actually have left. Multiply that by your mileage, round it down (for a safety margin) and commit that to memory.
Look where your fuel line connects to the tank. Its near the rear of the tank no ? Tilting the tank up 2" won't reduce access to your fuel hardly any. It didn't for me and I have a 3" lift.
