Heat
Old Aug 25, 2017 | 10:04 AM
pjpockets's Avatar
pjpockets
Default Heat
Can oil temp of 260 Degrees cause cylinder wall glazing. Bike has 300 miles, and still using regular HD 20/50. Ambient temp 90 degrees.
Old Aug 28, 2017 | 09:04 AM
archergodwin's Avatar
archergodwin
Depends on how long it was at 260... I doubt that the temp by itself is going to cause a problem other than decrease the life of the oil.
At 300 miles, you're likely to use a little oil as the rings may not have 'sealed' or matched themselves to the cylinder walls yet.
http://www.harley-performance.com/ha...brication.html
Old Aug 28, 2017 | 09:59 AM
robbyville's Avatar
robbyville
Probably not a legitimate answer to your question but...
I ride regularly in temps way beyond 90 (heck it was 91 at 5am here this morning). I've been living in this area for the last two years and my head temps as measured by my Powervision regularly hit 300, not sure how that translates into oil temps. I do have oil cooler and fans.
At any rate, when I disassembled my engine to put new cylinders and pistons on, I had no glazing whatsoever.
Old Aug 28, 2017 | 12:07 PM
nevil's Avatar
nevil
With only 300 miles on the bike, what makes you think the cylinders are glazing?
Old Aug 28, 2017 | 12:34 PM
jmeiers's Avatar
jmeiers
Just put Mobil 1 20w-50 Synthetic in it already and quit worrying. I have had my bike since new 2010 and swapped to synthetic at 30 miles and it still runs great today. All I did to break it in was a couple hard WOT runs and let it engine break to seal the rings.
Old Aug 28, 2017 | 10:55 PM
archergodwin
Actually not great advice for breaking in a motor... but hey, to each his own.
Old Aug 28, 2017 | 10:57 PM
OddJack's Avatar
OddJack
How did you measure the oil temp?
Old Aug 29, 2017 | 07:55 AM
jmeiers's Avatar
jmeiers
http://www.mototuneusa.com/break_in_secrets.htm
Maybe not good advice for you. I didn't follow this to the letter but did my own variation of it and my bike is living proof it works. You cannot tell the difference between my motor or another motor that was "broke-in" using the long drawn out process described in your service manual. I have also done this on a 2010 Toyota Corolla that is going 176,000 miles strong and a 2015 Ecoboost Explorer.
Old Aug 29, 2017 | 11:16 AM
skinman13's Avatar
skinman13
I always heard from the old timers to treat it like a woman, "Take care of her and break her in like you are gonna ride her." I am pretty sure they were referring to breaking in new rides because they were always looking at one when they were saying this and they were like all meek and, "yes, ma-am," around their old ladies.
But seriously, I have followed this procedure for every new car, truck, or motorcycle I have purchased...every single one...and the only problems I ever had with any of them were not related to internal engine failures attributed to improper break-in, nor did they wear out early, they had other issues like failed engine sensors, collisions, bad gas clogging filters a couple of times, and a '82 Datsun pickup engine that got AFU in high water. I currently have almost 100K miles on my '07 F-150 and it was broken in the same way I drive it today. I use Ford syn-blend with Ford filters and change every 7000 miles, no more, no less.
I do generally break in a newly rebuilt engine but it is not a specific procedure but more of take it easy for a few hundred miles until all the new parts get meshed and worn together and I am confident that everything is good before going WOT.
Hey, but to each his own...I just go by what learned from my elders and my own experience.
Old Aug 29, 2017 | 11:25 AM
cvaria's Avatar
cvaria
short answer, no. ride on and enjoy.
bike is already broken in.
