Just joined 2013 Dyna Stripped Primary Hole
Old Sep 12, 2017 | 12:59 PM
artest7's Avatar
artest7
Stage I
Default Just joined 2013 Dyna Stripped Primary Hole
Hello,
I'm Art from Seattle, WA. (GO SEAHAWKS!). I've always purchased used vehicles (cars/suv's) in the past but decided to FINALLY purchase my first bike, A BRAND SPANKIN NEW 2013 Dyna FXDC Custom Superglide, back in 2013 that is.
I decided to change the fluids myself this year and noticed that there were some metal shavings coming out when I took out the primary drain plug (size 1/2"- 20). When I went to tighten back up, it was bottoming out. So, I decided buy a 1/2"-20 helicoil kit.
Has anyone repaired a 1/2"-20 PRIMARY HOLE? I NEED HELP PLEASE! I think I may have ruined the threads but not sure! I SHOULD HAVE USED A OVER-SIZED PLUG INSTEAD! UGHH.....
Thanks to those (if any) who respond to my amateur mistake,
Art artest7@icloud.com
Old Sep 12, 2017 | 07:50 PM
archergodwin's Avatar
archergodwin
Unsure as to why you thought the plug was 'bottoming out' ? The plug is supposed to seat, with an o-ring on it.
Old Sep 12, 2017 | 08:24 PM
brad75raiders's Avatar
brad75raiders
You can still use the over size plug it has a cutting edge to it it will clean up the threads
Old Sep 13, 2017 | 11:14 AM
Kevin R's Avatar
Kevin R
I just changed the oil in mine and noticed the bolt not tight just tight enough to seal the o ring. I replaced all drain plug o rings and just put some teflon tape on the threads. Just snug them up. No need to feed them down.
Old Sep 14, 2017 | 12:32 AM
Blue Bob's Avatar
Blue Bob
I know it's a pain but PM me and I will fix for free
Just my way of contributing to the community
traildog
2014-2024 Touring Models
36
Dec 22, 2017 07:49 PM
emerican19
Jan 28, 2016 07:10 PM
Dino M
Nov 7, 2010 06:05 PM
dert
EVO
Jan 12, 2007 03:01 PM
pitbull1
13
Aug 30, 2006 01:10 AM
