security fob question
Old Sep 26, 2017 | 11:45 AM
upflying's Avatar
upflying
Default security fob question
My Dyna won't start, neither of my proximity security fobs are recognized but I can start the bike by entering the pin.
My fob batteries are 3 yrs old, is it common for both to fail simultaneously? I plan to go to Walmart to buy two #2032 batteries but am I missing something obvious?
Old Sep 26, 2017 | 12:08 PM
ktrick's Avatar
ktrick
I'd replace the batteries. It'll drive you nuts having to enter the code all the time.
darrenstoner's Avatar
darrenstoner
You should be able to start the bike without the fob, I know my local dealership have done it with my last sportster
https://www.lawabidingbiker.com/harleyalarm/
this link should help with a vid
Old Sep 26, 2017 | 12:11 PM
shorelasHD's Avatar
shorelasHD
You can get a two-pack of 2032 (or is ir 2025?) batteries for under $5. Treat yourself to a fresh set.
Oh, and don't store the Fob with the bike, the batteries will last longer, so I hear...
Old Sep 26, 2017 | 12:12 PM
nevil's Avatar
nevil
I change out my fob batteries every spring and carry a spare on the bike. Can't imagine they would last 3 years anyway.
Old Sep 26, 2017 | 02:23 PM
cvaria's Avatar
cvaria
double check your antenna under the seat. extremely unlikely that it came off but, have a look.
looks like:
Old Sep 26, 2017 | 03:21 PM
bigbadpoppa's Avatar
bigbadpoppa
It's recommended that the battery be be changed every 2 years.
also if your second fob isn't in use.. don't put a battery in it. It will drain the same rate as the one you use.
Old Sep 26, 2017 | 03:35 PM
rlamb54301's Avatar
rlamb54301
Change the fob batteries every 24 months and your good.
Old Sep 26, 2017 | 03:36 PM
adm's Avatar
adm
Yeah. Fob batteries. Change them both.
Old Sep 26, 2017 | 05:49 PM
Griff012FLHX's Avatar
Griff012FLHX
Here's a related story, We were over in Paso Robles, CA....At a motel and none of the bikes in the front parking lot would start, My Bike was in the back, So I rode around and turned it off, And then it would not start, So I got to thinking, And I pushed it just passed the front door of the Motel, It started right up, And so did all the bikes pushed past that point, Weird dead zone......Who knows....
