lower shocks, now a kickstand question...
Old Jun 14, 2007 | 02:01 PM
murfe's Avatar
murfe
Default RE: lower shocks, now a kickstand question...
thanks guys!
I'll probably slide the tubes up or something cheap like.... lowering the back today, and ordering a c&c seat in the next week or so.
Old Jun 14, 2007 | 05:10 PM
strich's Avatar
strich
is leveling the front end as simple as the back? i'm waivering on going with a pair of 412s for the back, but want to drop the front end. i'm just not really all that mechanically inclined.
Old Jun 14, 2007 | 05:36 PM
Punty's Avatar
Punty
The fronts are easier than the back just loosen the 2 screws on each fork, then slide the forks up, make sure they are the exact same height on both side and torque accordingly. Email or PM me if you get stuck and I'd be glad to walk you through it. step by step
Old Jun 14, 2007 | 05:40 PM
Trotter's Avatar
Trotter
I did mind in 20 minutes.....without a jack.....Just one side at a time
How did ya get the swing arm up far enough to bolt up the one side (11") you were doing first, when the other side was still hooked up and with a 1 " longer shock ?
Murfe
Jack the bike up just enough to take the weight off the shock.Wheel should still be touching the floor
unbolt the shocks top and bottom nothing drops
bolt up both shocks on the top (Blue Loctite)
let the bike down just enough so the swing arm (tire) comes up into the fender to the right height for the new shocks.
Install both bottom bolts (Blue Loctite)
20 min.. Use a jack.. Borrow if ya can.. or betterbuy one you'll use it
As far as the front.. Your call MyF.E. is stock and handles fine..
Kickstand is no problem
Old Jun 14, 2007 | 06:22 PM
tmworks's Avatar
tmworks
I didn't have any problems with my FXDX until I droped drop 3". The fix is simple, the tab on the kick stand that locks it into place also controls the hight. Just grind off the top a little.
See attached drawing.
[IMG]local://upfiles/29980/AB3ABCA384324C83B174BD0D8BCE7D5E.jpg[/IMG]
[IMG]local://upfiles/29980/9ACEFC9F980E4E08867BA33CED3AB4C6.jpg[/IMG]
Old Jun 15, 2007 | 08:38 AM
ravin cajun's Avatar
ravin cajun
Hey TMWORKS great looking ride. What brand windscreen are you running it looks good on your bike.
Thanks Ravin Cajun
Old Jun 17, 2007 | 04:21 PM
kiltiemon's Avatar
kiltiemon
Thanks for the hint, TMworks... I've made a date with my grinder for next weekend... Saves a trip to the bike shop and a hundred bucks for a "short" jiffy stand!!!
Jim aka kiltiemon
Old Jun 18, 2007 | 10:55 AM
LuvtheMud's Avatar
LuvtheMud
Punty
Date 6/14/2007 3:36:29 PM
Do you have pics of this step?
Old Jul 15, 2007 | 11:25 PM
tmworks's Avatar
tmworks
I know your post is a month old but, the windshield is a 14" winvest. I had to custom machine the brackets. When I put the pullback/ risers on I had to relocate the spedo and tach. The factory winvest brackets would work then.
jimlowe
Nov 6, 2013 04:58 AM
A Whole lotta Rosey
Jul 24, 2012 05:15 PM
Handycam
May 23, 2009 03:35 PM
Alan 123
Jan 6, 2009 05:16 PM
Jazz56
EVO
Jan 18, 2008 08:23 AM
