Brakes locking up, help!
Old Oct 7, 2017 | 10:12 AM
Max Headflow's Avatar
Max Headflow
Originally Posted by Pokey151
Sounds like you need a G string!!
I had this happen on an old street bike that sat for a long time. Flushed everything then went on a ride, within 5 mi. The Front would start to lock, only way to free it up was release the pressure at the caliper.
I'll save you 3 months of work. Because that how long it took me to figure it out. Pop the cap on the master cylinder (take all precautions to protect all surfaces from drips and slashing fluids) anyways, you can see the plunger (piston) that forces the fluid in the line. Well just close to it, you will see a tiny hole, that is a bleed path. It sounds like it's plugged. Take a G-string from a guitar. Stick it in the hole, it should pass down to the bottom. (Mine was about 3/4" deep) you can tell when you bottom out. Anyways. If it's plugged it will only go in just a couple mm.
Btw I use a g string from an electric guitar from a standard size 10. If someone plays the guitar in your house, you only need a short piece
Within​​​​​​ that pack the G sting is a size 17
I would agree with this.. There are 2 holes in the master cylinder that feed the piston that generates the pressure.. The small one is likely plugged. The small one is uncovered by piston cup and lets the pressure in the line drop. If it's plugged, as the brakes heat up the fluid expands and needs to escape from the line and back into the master cylinder. If it don't brakes will start to engage. Not sure why popping the reservoir cover stops the issue, could simply be time to let pressure drop or it is somehow involved in the blockage.
Welding tip cleaner or even a bristle from a wire brush should clear it out..
There might be something wrong with the new brake line. Something caught in it that is acting like a one way valve also but the issue seems to be the master cylinder.
Old Oct 7, 2017 | 10:23 AM
Smogbob's Avatar
Smogbob
Originally Posted by HrdNox
No..Yea,don’t over tighten it. Crush washers good? Like suggested, I’d keep my focus on the MC.
Yep +1 on above, the gstring sounds the way forward, after that reflush with new fluid, because if the pads have heated up the rotor the fluid would have boiled.
Old Oct 8, 2017 | 12:13 AM
skinman13's Avatar
skinman13
sounds like a classic master cylinder failure...2500 miles on a four-year old bike suggests that it is parked more than rode and those gaskets and seals deteriorate and brake fluid collects crud that settles in the bottom of the reservoir and sooner or later the crud stops up the vent hole and you get problems.
I'm thinking that just cleaning out the hole is a band-aid fix at best because whatever crud is in the bottom of the reservoir that got stirred up and clogged the vent hole in the first place is still there and it will eventually happen again.
When this has happened to me (twice now), I get an OEM rebuild kit and a couple of banjo washers for around $30 and rebuild it...and for around $50 more I can rebuild the caliper at the same time and flush out the line and change out the fluid and be good to go knowing my brakes are gonna work because the job was done right. Some folks may think this is overkill, and they maybe right for them, but it is not a big job or expensive and front brakes are pretty important to me...better knowing for sure than guessing and assuming...
Old Oct 9, 2017 | 06:54 AM
Nlstreetbobber's Avatar
Nlstreetbobber
So, I have thoughtof a probable cause. Let me know if you think it's the case... When I installed the bars and had the brakes and switch console off the bar, apparently the tip on the "brake light" plunger broke. I was aware this happend and my fix so that the brake lights would disengage was to wrap some black tape around the lever. It fixed the light issue but the tape on the backside of the lever was preventinf the master cylinder plunger from fully opening up.. (just a hair) I'll know later today if it worked... fingers crossed!! What do you guys think?
Old Oct 9, 2017 | 08:29 AM
jdvorchak's Avatar
jdvorchak
The return hole in the MC is called the "spooge" hole and it's plugged. It is a very tiny hole and easily overlooked. Anything you did with the lever isn't going to help the original problem of brakes locking up.
It's not a big deal to clean that hole. I'm surprised the "Mechanic" you told to flush the system didn't check that especially after hearing your problem. Now if you didn't mention the brakes locking up he would not check it. I'm further surprised he didn't test ride the bike after his work. The problem would have surely showed up and he should have addressed it at that time.
Go to a local music store and ask for the #10 guitar string. It's probably only about $2. I use a #80 micro drill bit in a pin vise to clean return or spooge holes.
Old Oct 9, 2017 | 09:20 AM
Max Headflow
If you are limiting the return of the master cylinder piston to it's home position, there is a strong possibility that the small hole blocked by the piston and the brake lines can't release the line pressure. The brake fluid does not need to boil but simply expand due to heat to cause the brake drag.. Simply using the brakes can cause enough heat.
Old Oct 9, 2017 | 09:29 AM
NORTY FLATZ's Avatar
NORTY FLATZ
Are you using the exact lever that came with that M/C? I had the same issue years ago on a different bike. It turns out the lever push blade wasn't correct for the M/C. It wouldn't let the pressure bleed back fluid into the res.
Old Oct 9, 2017 | 10:04 AM
Nlstreetbobber
Yea I forgot to mention. I did stick a piece of wire from a wire brush into the holes inside the MC. And my lever (OEM) fully returns to the fully open position after removing the built up black tape. 60 kms so far and no lock ups. Hopefully it was one of the two possible causes. Time will tell! Thanks everyone!
Old Oct 9, 2017 | 10:23 AM
NORTY FLATZ
That's precisely the problem. Remove the tape as the plunger return distance is critical.
Last edited by NORTY FLATZ; Oct 9, 2017 at 12:51 PM. Reason: darn phone graphics...
Old Oct 9, 2017 | 10:42 AM
wlcjack's Avatar
wlcjack
Well done!
Dynaglide92
2014-2024 Touring Models
Dec 25, 2018 07:17 PM
rebeltruce
Sep 23, 2017 08:07 AM
Donjohnson
May 31, 2017 07:13 PM
BOSOXFan
Jan 26, 2014 08:22 AM
tjdlsj
Dec 26, 2011 08:50 PM
