2008 fxd shifter rod
Old Oct 14, 2017 | 02:08 PM
joesride's Avatar
joesride
Default 2008 fxd shifter rod
What prevents primary oil from leaking out of shifter rod , where the rod runs through the inner and outer primary cases . I took my primary apart to remove and replace my primary chain adjuster and compensator , bike now has 87k miles on it and has been fantastic , i figured i would change out those items due to compensator spring seemed to be getting weak .
Old Oct 14, 2017 | 02:10 PM
joesride's Avatar
joesride
When i took it apart there were no seals on either side of primary cases where the rod runs through and i found that odd ?
Old Oct 14, 2017 | 02:19 PM
misfitJason's Avatar
misfitJason
It's a mls gasket in between the two primary halves. Where the shifter rod runs through it's a hallow void that doesn't actually go into the inside of the primary
Old Oct 14, 2017 | 02:32 PM
joesride's Avatar
joesride
i reckon that little round tower gasket isolates the shaft from any oil intrusion once both the outer primary is torqued down . that little gasket is was not in my primary gasket seal set i bought to put it back together . I will pick up a new one before i put her back together .. This particular bike now has 87k miles on her , has done 14 trips from the Florida panhandle up to South Jersey and back , with really no troubles except for a rear wheel bearing issue . I have noticed that starting the bike after its warmed up there is some kick back etc which i suspected to be the Compensator spring getting weak etc . I am also installing a Hayden chain tensioner whilst in there . Thanks !
Volant1006
Jun 3, 2016 12:31 PM
beary
EVO
Mar 11, 2015 02:46 PM
skdvr
Sep 9, 2011 09:58 AM
SICKBAGGER
Jul 10, 2010 06:37 PM
motox285
Jul 1, 2010 10:24 PM
