Help! 99 Dyna FXLD No power
Old Oct 15, 2017 | 09:14 PM
ThatRyanGuy's Avatar
ThatRyanGuy
Stage II
Default Help! 99 Dyna FXLD No power
Just got onto I 95. Bikes running fine. The bike shuts off while riding. I have no lights, turning the key doesn’t turn anything on. Hitting the ignition switch has no response.
Something near the fuse box keeps making a constant clicking noise. If I take the key out of the bike it still keeps clicking once every 15-20 seconds. Had to disconnect battery to get it to stop. Any ideas what the cause is and how to fix it? I’m still on the side of the road FYI. Five mile push to get her home!
Old Oct 16, 2017 | 06:30 PM
Rusty19MCSFV's Avatar
Rusty19MCSFV
Clicking sounds like you may have a relay that has gone bad and is cycling. Best bet is to start with fuses, then check relays, and start tracing power if you have a schematic?
Old Oct 17, 2017 | 12:04 PM
nevil's Avatar
nevil
Go over all your battery and ground connections to make sure that they are tight and clean.
Try a new relay.
Old Oct 17, 2017 | 12:47 PM
fxdlx's Avatar
fxdlx
Have a look at that ign switch. They’re problematic
Old Oct 17, 2017 | 02:59 PM
NORTY FLATZ's Avatar
NORTY FLATZ
Battery condition? Swelling?
Check the battery ground circuit.
Old Oct 17, 2017 | 06:47 PM
wlcjack's Avatar
wlcjack
You would be wise to disconnect the battery before you turn your back on the bike. It sounds like the making of a fire until sorted out.
ThatRyanGuy
Electrical/Lighting/Alarm
Oct 16, 2017 09:15 AM
scanales85
Jul 24, 2017 02:05 PM
Colleen
May 6, 2017 07:46 AM
Paesani241
11
Apr 17, 2014 10:38 PM
dmayer
Mar 4, 2011 07:21 PM
