Problems starting my Dyna
Old Apr 14, 2014 | 06:36 PM
Paesani241's Avatar
Paesani241
6th Gear
Default Problems starting my Dyna
Took the bike out this weekend in the nice weather. Hopped on it to head home, turned the ignition with to "on" and everything lit up as usual. As soon as I hit the Start button, all the power shut off with a loud click. Turned the ignition switch off and back on but no power at all. Ended up getting towed home.
Removed and checked all fuses - all in tact. When I plugged in the Maxifuse (40 amp), I heard the power click on. I turned the ignition switch to "on" again and everything lit up like normal. As soon as I hit the start button, same result: Loud click and everything shuts off. Any idea on the problem here???
Old Apr 14, 2014 | 06:41 PM
dyna105's Avatar
dyna105
Replace the relays....can pick up non-harley relays at any auto part store. Also if you have a key fob....change the batteries in it. Will effect the starting sometimes. The main problem for me has been the relays.
Old Apr 15, 2014 | 11:20 AM
Paesani241's Avatar
Paesani241
6th Gear
I'll get to auto store asap and pick up a couple relays. Hopefully this will take care of it.
Appreciate the help!
Old Apr 15, 2014 | 11:44 AM
nevil's Avatar
nevil
While you're at it, make sure your battery and ground cables are clean and tight.
Old Apr 15, 2014 | 01:03 PM
Paesani241's Avatar
Paesani241
6th Gear
Battery is in good shape and all contacts are tight (as far as I can tell).
Old Apr 15, 2014 | 04:21 PM
miami's Avatar
miami
Get both stater relay and system relay, around $20
miami's Avatar
miami
sorry, s/b starter relay
Old Apr 15, 2014 | 04:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
What do you mean by that? Have you had the battery load tested, have you disconnected, cleaned and reconnected the battery cables?
A bad relay is not going to shut off the entire system electrics.
Don`t go out buying relays or any other parts until you do some troubleshooting.
What year is the bike?
Old Apr 15, 2014 | 08:46 PM
nevil's Avatar
nevil
A lot of times the ground strap to the frame/starter is overlooked, people just check the connections at the battery. If it's not right it can cause all kinds of strange things to happen.
Old Apr 15, 2014 | 10:10 PM
Paesani241's Avatar
Paesani241
6th Gear
Battery is relatively new and has always been on a trickle when not in use. I disconnected battery and reconnected. All wires appear to be tightened properly.
Went to HD earlier today and bought a new relay for $6. It was cheaper there than at Advance Auto Parts and I would have to wait for delivery at Advance. Took out the old starter relay and put in the new - started right up! Hoping this isn't a fluke, I'm gonna test it out again, close to home, once the weather gets nice again. I'm crossing my fingers...
