Higher octane is NOT better. Run the minimum required to prevent pre-ignition (aka detonation, ping, knock). Higher octane reduces burn speed and has lower potential energy per volume. My carbed 88" runs great on 89 octane.
He's in Singapore which means he is likely talking about 95 and 98 RON. 95 RON = 91 Octane here and 98 RON = 93 Octane here.
I would definitely start with an immediate oil change. As previously noted, the way you were running when this happened may have overheated the oil, causing a loss of viscosity. Chris is right on the money about octane... You only need a higher rating if you're running so much advance (or compression) that you're getting some detonation...
I've been scratching my head pondering whether to reply. A few thoughts...
Oil doesn't impact engine performance unless you don't have sufficient. Yeah the dyno freaks like thin stuff for high numbers but generally speaking you'll see NO significant difference in engine performance.
If you moved from Syn 3 (20w-50 I recall) to a straight 50w oil there is almost no difference anyway once at operating temperature. The cold properties are different but once hot they are almost the same viscosity. The warm up on straight 50w risks damage to your motor if the temp get too low.
If you really did get any improvement from thicker oil the only impact it could have is the lifters. If you had a failing lifter that may have improved short term from the thicker oil.
Then with the "silly little revving party parade" the lifter probably gave up. Of course you you could have bounced a valve off a piston and bent it a bit causing compression loss if you over revved the motor.
I'd run a compression test (aka cylinder pressure test). Do post the results.
That's my guess and worth everything you paid for it. YMMV.
Now this is logical... I like the lifter theory, it fits in properly with the whole story. Years ago, I had a time trial car that started to let too much oil past the rings... I managed to get the rest of the season out of it by running straight 50 weight. A compression test would be useful, but a leakdown test might really pinpoint the problem.
