FatBob running lean, vibrating
Old Dec 25, 2017 | 02:56 PM
Huggerbugger's Avatar
Huggerbugger
Default FatBob running lean, vibrating
09 with 15k. EFI. Fuel pump?
Old Dec 25, 2017 | 06:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
What were the indications that's it's running leaner than factory? ECM connections clean and dry?
Old Dec 25, 2017 | 07:13 PM
Huggerbugger
White plugs.
Old Dec 25, 2017 | 08:18 PM
TexasScooterTrash's Avatar
TexasScooterTrash
You need an EFI tuner.
Old Dec 25, 2017 | 08:28 PM
Huggerbugger
Been looking at them, but hate to pop out 400 clams just to make it run better, and no guarantee that it will. My '06 Road King doesn't have one and it's smooth as butter.
Old Dec 25, 2017 | 08:35 PM
JustDave13's Avatar
JustDave13
Originally Posted by Huggerbugger
Been looking at them, but hate to pop out 400 clams just to make it run better.
See post 1
Old Dec 26, 2017 | 12:23 PM
seniorsuperglideE8
Did you change the exhaust and intake without adding a tuner? I changed the exhaust and opened the intake, then installed a V&H FP3 using their canned map and all is fine on my Road Glide Ultra. Since then I also put on the plumbing for external oil vapor breathing, keeps the vapors out of the cylinder. I'm sure the FP3 will work for you. If you have a smart phone install the APP and do the demo/tutorial. It's that easy.
Old Dec 26, 2017 | 12:28 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
Plugs are normal when white on a good condition modern FI motor. Adding fuel increase fuel/air ratio only decreases engine life.
Poking around in stop and go city travel can tan them but a interstate run of 55-75 of 50 miles will leave them white.
This is not your gpaws carb EVO
Old Dec 26, 2017 | 01:14 PM
Huggerbugger
Had SE muffls on it and it ran great without changing anything. Tried some louder pipe, too loud and put the SEs back on. Now, it feels like I'm running on one cylinder. Don't even want to ride it.
Old Dec 26, 2017 | 01:26 PM
crazytown's Avatar
crazytown
Why don't you just go back to stock then?
