New Grips Installed
Old Jun 17, 2007 | 09:37 PM
Dynamite17's Avatar
Dynamite17
Default New Grips Installed
I installed a set of Kuryakan Iso Grips today and found the info from a thread on this board extremely useful. Also the pics and details about the right grip removal from the shop manual great.
There does seem to bit a more free-play in the throttle now (amount I can rotate before any increase in engine speed). Does anyone else notice that? I counted the threads on both cables and re-installed exactly the same. My idle is right about 1000 RPM, there is not much change on that adjustment.
For the left grip, just cut/peeled them off and used the complete contents of the small glue tube provided. All seems fine there.
B
Old Jun 17, 2007 | 09:41 PM
torchmaster's Avatar
torchmaster
Default RE: New Grips Installed
Sounds like ya need a slight adjustment on the throttle cable. Do you have the manual for your bike!
[hr]
Old Jun 17, 2007 | 09:53 PM
06dynablack's Avatar
06dynablack
what torchmaster says
Old Jun 17, 2007 | 10:02 PM
madden23's Avatar
madden23
Glad you didn't lose the little brass stops at the end of cable, I dropped one took me an hour to find it. grrrr
Old Jun 17, 2007 | 10:12 PM
06dynablack
yep picked up extra ferrulles i did.good thing because never did find the clip
Old Jun 17, 2007 | 10:14 PM
Dynamite17's Avatar
Dynamite17
ORIGINAL: madden23
Actually I got the cable and attached ferrule out of the grip slot, then when I let go of the cable, it sprung back and the ferrule took off. I carefully followed the ping ping ping of things it bounced off of and found it just below the voltage regulator on the ground. Averted disaster.
I tightened up the throttle cable adjuster about 4 turns and took up the freeplay. Described on page 1-42 of the shop manual, thanks.
B
Old Jun 17, 2007 | 10:25 PM
intempestivus's Avatar
intempestivus
I had to tighten up the throttle cable to take up the free play after installation too. About 3 threads worth.
Old Jun 17, 2007 | 11:34 PM
rcpilot_971's Avatar
rcpilot_971
[quote]ORIGINAL: Dynamite17
ORIGINAL: madden23
B
I put new grips on mine today also and lost one of the brass ends had to run to the dealer only a mile away when the parts guy had th book open to look up the part # for the brass ends I seen there were C clips in there and I did not see them on mine do they hold the cable in to the housing ?
Thanks Tim
babaharley
Jan 10, 2017 12:59 PM
Darrin Palmer
Mar 19, 2016 07:21 AM
dlporter
Jul 28, 2015 10:02 PM
Florida Swamp Yankee
Jan 26, 2014 02:45 PM
Whiffleboy
Feb 14, 2006 10:12 PM
