Help me diagnose
Old Jan 15, 2018 | 01:48 PM
TalkeetnaFlyBoy's Avatar
TalkeetnaFlyBoy
Stage III
Default Help me diagnose
My 2009 Street Bob has been sitting in the cold the last several months. It's on a battery tender and the battery seems fine. I took it out to run it around the block a couple of times and when I try to start it I just get clicks. I've attached an audio file. Anyone know what my problem is? Fuel problem?
File Type: mp3
Old Jan 15, 2018 | 01:51 PM
MURPHCC1's Avatar
MURPHCC1
Welcome from Mass.
how old is the battery?
Sounds to me like it's toast.....
CHARGE it.....NOT on tender......then have it load tested.....
Old Jan 15, 2018 | 02:01 PM
SC07Bobber's Avatar
SC07Bobber
Battery might be frozen up. I'd recommend pulling the battery and keep it on the tender inside the house for a day and then try it again. That might work for you.
Old Jan 15, 2018 | 02:02 PM
TalkeetnaFlyBoy
Stage III
Thanks all. I'll pull the battery.
Old Jan 15, 2018 | 02:03 PM
crusader1xxx's Avatar
crusader1xxx
Noise is the starter clicking due to not enough battery to turn it over. Need to load test the battery, then check your stator....
Old Jan 15, 2018 | 02:15 PM
justfnride's Avatar
justfnride
I'd agree, sounds as if there isn't enough juice to engage the starter. Also check the battery connections. Fastest way to tell if it's the battery is to connect it to a car with jumper cables and attempt to start the bike WITHOUT the car running. A car battery should allow you to crank over crank the bike normally. That's where I'd start (pun intended).
Old Jan 15, 2018 | 02:35 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Dead battery.
Other than that it seems fine...
Old Jan 15, 2018 | 03:54 PM
TalkeetnaFlyBoy
Stage III
Was totally the battery. Thanks for helping a newbie out.
bigjosh42
Electrical/Lighting/Alarm
17
Feb 8, 2019 12:52 AM
dvitaso777
Feb 27, 2018 06:39 PM
JackGib46
Feb 25, 2013 11:43 AM
TAHOE GUY
Dec 12, 2012 10:48 AM
timebandit60185
Nov 28, 2009 08:14 PM
