quick help-fluids and amounts
Old Jun 18, 2007 | 05:57 PM
98fxd's Avatar
98fxd
Default quick help-fluids and amounts
going to the shop right after work to pick up stuff full fluid change, don't have my manual here. can you guys tell me how much of what i need to purchase. primary, tranny, crank case? any o-rings or gaskets? im ctaching a bus in 5 minutes so any help would be helpful.
thanks a lot
Old Jun 18, 2007 | 06:59 PM
thrillseeker's Avatar
thrillseeker
Default RE: quick help-fluids and amounts
looks like you need to give us more than five minutes to respond
you need to buy (which does not mean USE)
4 qts oil
1 qt gear oil
1 qt tranny oil
manual suggests inspecting o-rings on drain plugz but I haven't had to replace them. The only gasket you would need replace would be for the primary cover, which isn't removed for a basic drain and fill.
Whale
Oil Archive (no new posts)
Feb 29, 2012 12:20 PM
blackknight1967
Jan 22, 2011 09:10 PM
Ghost2277
Aug 13, 2010 11:50 AM
call911s
Nov 17, 2009 06:45 AM
85green
Aug 28, 2007 11:48 AM
