Idle control module
Old Feb 10, 2018 | 07:44 PM
Angeltrumpettech's Avatar
Angeltrumpettech
3rd Gear
Default Idle control module
2011 Dyna street bob
clicking noise coming from IAC after switch is turned to ON position. Bike won’t crank over.
Part number on module is 59603.
Could a faulty module stop the system from cranking the engine over?
Old Feb 10, 2018 | 07:56 PM
MURPHCC1's Avatar
MURPHCC1
I don't think so.....The clicking noise would be the IAC actuating.....sounds like it's working.....
any codes thrown?
Old Feb 10, 2018 | 08:02 PM
Angeltrumpettech
3rd Gear
I didn’t see any codes.
the bike will crank intermittently. When it cranks over no clicking from the module. When it doesn’t crank the clicking starts. I disconnect the module clicking stops.
I guess my question is, is that module connected to the starting system which would prevent the circuit from being complete , hence , no crank.
Old Feb 10, 2018 | 08:44 PM
MURPHCC1's Avatar
MURPHCC1
No idea.....got a Diagnostic manual?
Old Feb 10, 2018 | 08:49 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Starter system problem. You said you did not see any error codes. Well, if you unplugged the IAC, it will throw an error code. Look up checking error codes on you tube for your bike. Check your battery terminals for good contact and check for a good clean chassis ground.
Old Feb 11, 2018 | 09:37 AM
Angeltrumpettech
3rd Gear
Thank you
Old Feb 11, 2018 | 03:00 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did you check the voltage on the battery, you mentioned when the cranking (engine spinning) it starts clicking. Original battery?
Old Feb 11, 2018 | 03:15 PM
Angeltrumpettech
3rd Gear
Found the problem. Went ahead and cleaned out the OAC , wow , smooth throttle.
wt street bob
Milwaukee Eight (M8)
13
Apr 4, 2024 09:44 AM
Bradw71019
Jun 28, 2019 02:20 PM
Timberjkd
Nov 17, 2018 07:22 PM
BadPiggy
Oct 5, 2008 09:01 PM
dragpipes68
Ironhead
Sep 12, 2007 10:35 PM
